charcoal canister removed?
Old Jan 10, 2012 | 10:43 AM
bigpunn421's Avatar
Default charcoal canister removed?
with the charcoal canister removed should i plug the throttle body nipple at the top of the TB? or leave it unplugged?
i noticed fuel smells too/ but i guess thats normal.
ive been through 20+ threads and most dont have pics anymore. and no one mentions plugging the top nipple where it connected to the throttle body.
any info let me know
Old Jan 10, 2012 | 10:53 AM
GagnarTheUnruly's Avatar
Default Re: charcoal canister removed?
The fuel smell is from fuel evaporating out of your tank and being wasted into the air. Why did you remove the canister?
Old Jan 10, 2012 | 12:14 PM
TheRealTegger's Avatar
What year Integra?
Old Jan 10, 2012 | 01:57 PM
DirtyDA9's Avatar
I removed mine too, it looks better, that's why he removed it, and that's why I did it too.
Old Jan 10, 2012 | 01:59 PM
Dc4LsTeG's Avatar
EK9
Old Jan 10, 2012 | 02:02 PM
It collects fuel that evaporates in your tank which:
1) saves you gas, because you aren't paying for gas that will just evaporate out of the tank
2) prevents fuel from being wasted and sent into the atmosphere
You might as well drill a hole in the top of your fuel tank.
Old Jan 10, 2012 | 02:12 PM
DirtyDA9's Avatar
You only lose a maximum of 2mpg, hardly. And it's more of a EVAP thing, not a fuel economy thing.
Old Jan 10, 2012 | 02:16 PM
92DAB16A's Avatar
Yea but you are realsing gas fumes in the air wich causes smog.
Old Jan 10, 2012 | 02:29 PM
Not anywhere close to 2mpg. The mileage-loss from evaporation is so tiny as to be almost immeasurable.
Assuming a non-intrusive pre-OBD-II system...
The primary mechanical problem with removing the EVAP canister is that there'd be no pressure-vent for the fumes in the tank. The gas cap has a one-way valve in it, and pressures are relieved through the canister, with the resulting scrubbed-air vented to the atmosphere.
If the canister is removed, both the hole in the throttle-body AND the lines to the tank need to be plugged. Then you'd need to install a 2-way vented cap, which might be tough to find.
OP would be better advised to move the canister and its solenoid into a non-visible location, such as inside a fender.
Old Jan 10, 2012 | 02:33 PM
racebum's Avatar
you don't want to plug those lines. causes a pressure build up when it's warm out. you pull the gas cap and you'll have a lot of vapor escape.
you don't need the solenoid but should keep the canister. plum the canister straight to the TB nipple
as for the guy who said it looks better.....c'mon man, it's stuffed in the back of the engine bay.
Old Jan 10, 2012 | 03:39 PM
Maybe a tank a year. But it's the combined effect of 1000 people that does the damage.
Old Jan 10, 2012 | 04:58 PM
DirtyDA9's Avatar
@racebum
It also stands out like a sore thumb. I guess your one of those people that don't liked tucked bays and think they are stupid, but guess what, just like "hellaflush", there are people that like it.
Old Jan 10, 2012 | 05:12 PM
RookieCivic's Avatar
@racebum
Agreed!!!!
Old Jan 10, 2012 | 05:15 PM
Ill make sure to get a drill and start goin at my tank!
I love my cars like i love my women shaved! although mine isnt my daily you will never notice any gas shortage in your tank. and smog well if your that worried come to missouri there is no such thing as smog. Love it!
Old Jan 10, 2012 | 05:20 PM
DirtyDA9's Avatar
Packing bags to move to missouri now... lol
Old Jan 10, 2012 | 05:24 PM
lol ya its so nice only thing you cant do there is run alc. on the street but everything up to 110 octane you can!
Old Jan 10, 2012 | 05:59 PM
racebum's Avatar
@racebum
if you mean hacking the abs, devaluing the car, ,making it slower and less safe, then yes, i do generally make fun of those people
it's like showing off your retardedness and then being proud of it
Old Jan 10, 2012 | 06:34 PM
bigpunn421's Avatar
my car is a 1995 obd1. i pluged the throttle body nipple and it seemed to idle better. im going to test drive this weekend if its nice out. what was the vent hooked to? the gas vent with a canaster?
cars setup is a jdm b18c, JRSC @10psi, fuel setup, type r lsd and b16 gears. plus more. with a omni 70mm throttle body, tuned
can i plug the gas tank vent? i thought i needed to let it vent.
plus my car doesnt have abs and i have a manual steering rack.
heres a dirty picture
[IMG][/IMG]
Old Jan 10, 2012 | 07:06 PM
DirtyDA9's Avatar
Any modifaction you do depreciates the value of a car. And I'm not talking brake tucks and ****, and doing a wire tuck doesn't make the car less safe if you do it right. Removing the charcoal canister is just like removing ac and compressor, and power steering. Free's up a lot of space. If you don't like it, well, who cares.
Old Nov 24, 2016 | 05:29 AM
Omair Anwer's Avatar
Icon6 Re: charcoal canister removed?
Hi guys, hope you are all doing well. So here's my story, i am running a honda civic 2000 and its the love of my life well i somehow i had to change its throttle body and the one i got has this nipple for the carbon canister. My original throttle body didnt have any thing like this. My idle speed is perfect and my car is smooth and i have no issues CEL neither.
Now the question is that should i plug this nipple on the throttle body ? i mean vapors going into the environment i completely understand that but any impact on the performance ? should i plug it or not especially considering i dont have a carbon canister by default in my car.
Thanks for your help as always.
Old Sep 13, 2017 | 09:11 PM
Ben Hunnel's Avatar
hey I need help on doing a full wire tuck on a 94 Honda civic
Old Sep 25, 2017 | 08:37 PM
89brokendownEF's Avatar
​​​​​​​Im having problems with my vent, my car stinks like gas I don't even wanna drive it. I been driving other teg
Old Sep 27, 2017 | 09:49 AM
CandyRedRC46's Avatar
Sometimes my 2000 Integra does this on really hot days, when idling in a hot parking lot for long periods of time. I assume it is just the canister getting overwhelmed.
Old Sep 27, 2017 | 05:18 PM
i had shop change my feed, return, and vent, my car stinks like gas now and has a engine code
skafia
May 1, 2020 10:28 AM
meece0927
Apr 9, 2013 06:33 AM
alfee
Apr 14, 2005 12:40 PM
turbologist
Oct 7, 2003 06:00 PM
KooK
May 26, 2003 11:08 PM
