SOHC Blocks.
Old Oct 8, 2002 | 02:19 PM
bleebdat's Avatar
Default SOHC Blocks.
Between all the 1.6L blcoks is there any huge difference that would make one a better choice that the either, like stronger rods, better oil pump etc... not higher and lower compression #'s.
Old Oct 8, 2002 | 04:27 PM
oldskool_rex's Avatar
Default Re: SOHC Blocks. (bleebdat)
naw, the 1.6l blocks/rods are basically all the same. I have some piston specs up too...
http://www.heeltoeauto.com/dseries/dseries1.html
Old Oct 8, 2002 | 05:05 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: SOHC Blocks. (oldskool_rex)
a couple of things to consider.
A6 crank is superiour in oiling than other D16 cranks. VTEC oil pumps flow twice the amount of non-VTEC.
and it is rumoured that A6 block has better webbing than others.
stan
Old Oct 9, 2002 | 09:56 PM
bleebdat's Avatar
Default Re: SOHC Blocks. (90crxsi)
Cool thanks for the info guys, is it possible to put a vtec oil pump in an a6 block?
Old Oct 9, 2002 | 10:02 PM
Louie B.'s Avatar
oooo, good question, I'd like to know too!!!
Old Oct 9, 2002 | 10:14 PM
ExospeedAMcrx's Avatar
the A6 is the best block to build up on.
Old Oct 10, 2002 | 09:58 AM
bleebdat's Avatar
ttt
Anyone know the answer to this?
Spoon84
Jun 7, 2010 04:28 AM
BoostedEgHatchFl
Oct 26, 2005 06:10 PM
Guru Designs
Oct 1, 2004 09:29 PM
GapxGuy
Jan 20, 2003 09:50 AM
