ok, rod bearing part numbers throwing me through a loop
B20B with OEM crank and crower steel billet H beams fresh out of the box.... ordering a set of rod bearings for the machine shop, however im showing multiple part numbers...
CB1461P comes up under the B20
CB1353P comes up under the B18A/B
now the rods are for the B18A/B which i assumed, and know that the B20B uses the same LS crank, why the two part numbers for the standard sizes? ACL interchange for the B18B part number 4B1946 but the interchange for the B20 is 4B1956 as well, again two different part numbers for supposedly the same crank/rods?
BMo Tuning
26
Mar 20, 2012 10:09 AM
be18see1
21
Nov 9, 2008 09:47 AM
