oil restrictor removal for zc block?
Old Jan 9, 2012 | 12:01 PM
blacktibby07's Avatar
Default oil restrictor removal for zc block?
Where's it located so I can pull it?
Old Jan 19, 2012 | 03:59 AM
Default Re: oil restrictor removal for zc block?
Ok I did the mini me swap and read many forums, some state with zc block to pull it some dont, anyways.... Is this a problem? Anyone know difference between having one in and out? Location?
Old Jan 19, 2012 | 06:34 AM
24TEN's Avatar
PHANTOM MENACE
Depends on which specific ZC block you have. I'm under the assumption you are using a non VTEC SOHC ZC since you referenced a mini me conversion. If you actually read many forums I'm quite surprised you didn't see a picture of the oil jet. It's located between #2 and #3 cylinder on the intake side of the blocks mating surface with the head (I'm assuming you had seen it and hopefully pulled it out). All the engines essentially have them, main difference here for your specific situation, both the block and the head have one. Non VTEC engines have it located in the block (88-95) while the VTEC engines have it in the head. If you run both I believe that I had read somewhere that you won't have sufficient pressure to activate VTEC but I don't have first hand experience with that.
Old Jan 19, 2012 | 01:10 PM
i never checked before i put head on, my vtec does always pop tho
Old Jan 19, 2012 | 01:50 PM
24TEN's Avatar
PHANTOM MENACE
Personal pic just so you know where it's at, do you recall seeing it there?
Old Jan 20, 2012 | 01:36 AM
I'm pretty sure the wasn't there, so what zc block do I have then?
89blackef
Feb 11, 2012 04:27 AM
charlieboyhonda
Oct 24, 2007 04:09 PM
Crxsamurai
Aug 24, 2006 04:46 PM
Civic1.6VTEC
Mar 1, 2005 07:08 PM
rev-speed
Apr 22, 2004 07:37 AM
