LSV Turbo Major smoke from valve cover
Old Jan 9, 2012 | 09:25 AM
ay_billy's Avatar
Default LSV Turbo Major smoke from valve cover
So I have lots of smoke coming from the valve cover breather. I dont have a catch can hooked up. LS bottom b16 head. Stock internals on the block, built head. Running 5lbs of boost, tuned at alot more.
Go auto top mount
.70 trim jdm sport turbo
rc 750 injectors
Old Jan 9, 2012 | 09:30 AM
EJ8_Man's Avatar
Default Re: LSV Turbo Major smoke from valve cover
White smokey steamy vapor? Like the kind you get when you have coolant in your combustion chambers? Or coolant in the oil that is vaporizing? Or is it smoke from burnt oil?
What's the oil look like?
Old Jan 9, 2012 | 09:35 AM
Wrona's Avatar
5 psi of boost... on what turbo check ur oil and coolant level
Old Jan 9, 2012 | 11:07 AM
ay_billy's Avatar
oil looks clean. coolant all there? Ill keep an eye on the coolant but no loss.
Its white smoke, i didnt see a blue tint to it though?
I let my car idle for 15 min to see if it would "clear up" but no. It had been smoking but not that bad from what I understand.
.70 trim jdm sport turbo. Restrictor on the feed line.
Water and oil levels appear fine.
Old Jan 9, 2012 | 11:11 AM
fungus mungus's Avatar
White smoke is usually an indicator of water where it's not supposed to be.
fm
Old Jan 9, 2012 | 11:14 AM
bvillarreal's Avatar
bump im having the same problem exactly lol
Old Jan 9, 2012 | 11:19 AM
ay_billy's Avatar
fm
Ok. Other then the head gasket, what else would cause water to get in the wrong place?
Is there a way to check the hed gasket without a leakdown test? I dont have a compressor at home
Old Jan 9, 2012 | 11:24 AM
ay_billy's Avatar
hopefully we get answers
Old Jan 9, 2012 | 11:26 AM
Dc4LsTeG's Avatar
EK9
Is it comming out of the exhaust to?could be valve seals or piston rings
Old Jan 9, 2012 | 11:29 AM
Wrona's Avatar
get a compression tester its cheap and do a compression test also u can get a block tester to see if u have exhaust gas in the coolant
Old Jan 9, 2012 | 11:32 AM
ay_billy's Avatar
Ok. I'll try to get a comp tester at autozone and put up results later.
How do you use the block tester? I had asked for a comp tester, and they tried giving me a block tester and some liquid??
Old Jan 9, 2012 | 11:33 AM
mayfly's Avatar
what about to much fuel? like running rich?
grumblemarc's Avatar
The Grumpiest
Valve seals? Blown turbo seal?
Old Jan 9, 2012 | 11:34 AM
The Grumpiest
That would come out of the tailpipe.
Old Jan 10, 2012 | 03:05 AM
anothersickhatch's Avatar
Sounds like blow-by to me. how many miles are on the block?
Old Jan 10, 2012 | 05:15 AM
kyden's Avatar
sounds like you cracked a ringland. compression test time.
Old Jan 10, 2012 | 05:49 AM
SiRCiviC94's Avatar
there so many opinions here we need a video. I opened my oil cap and some reg smoke or steam came out not much....heard it shouldnt do that but every engine I seen around my place does
Old Jan 10, 2012 | 07:30 AM
sde780's Avatar
^This. How are you venting your crankcase? If you're running stock PCV system, ditch it ASAP.
Old Jan 10, 2012 | 07:48 AM
Turbo-LS's Avatar
It's excessive crankcase pressure and blow by most likely due to cracked ringlands. Blythe first post saying its tuned on a lot high boost pressure on stock ls bottom end and probably to much timing you cracked those babies real quick. Time for a tear down and rebuild and tuned properly
Old Jan 10, 2012 | 08:00 AM
Dc4LsTeG's Avatar
EK9
X2
Old Jan 10, 2012 | 08:43 AM
ay_billy's Avatar
The block has low miles and we run the car at 5 psi, I believe that is how its been run for a while now.
Im going to run out and take a few pics, because likely, the turbo is coming off. :\
Old Jan 10, 2012 | 08:53 AM
kyden's Avatar
low miles and 5 lbs really doesn't mean anything though.
Old Jan 10, 2012 | 09:17 AM
ay_billy's Avatar
I cant see whats going on in the pcv system, Im going to jack it up in a bit, cause I cant see it from above. It is not connected to the intake manifold
It might be plugged? The bottom end was just replaced so maybe they forgot to put the pvc somewhere.
Wouldnt ringlands cause me to smoke bad from the tailpipe too?
Would this work?
http://www.brfittings.com/index.php?...&product_id=56
Old Jan 10, 2012 | 09:21 AM
BigMike0147's Avatar
I had the same problem with my stock LS setup. It was ringlands. Compression test should be able to show you. You want about +/- 10% difference in the cylinders. When I tore mine down (since one number was lower), it turned out like three of the pistons had broken ringlands.
Old Jan 10, 2012 | 09:29 AM
Turbo-LS's Avatar
Leak down test will point out the problem if it's engine internal failure. Turbo will not cause crankcase smoke only exhaust smoke. Crankcase smoke is from ringlands cracked, excessive blow by, or poor ventilation causing it to damage something else
