93 accord wont start all of a sudden
Old Jan 9, 2012 | 06:07 AM
furiouscobb's Avatar
Default 93 accord wont start all of a sudden
always drives fine. gettin ready to sell. cleaned the motor up so i have touched everything. degreased sprayed with water etc. coverd the distributor and coil first to not get wet. drove it twice after that no problem. however it now kicks the fan on as soon as the key goes off and the fan off when the key is switched back on. never did this before. dissconnect pos battery cable shuts fan off. played around with this for awhile touching some connections thinking maybe something was loose. All conections connected . still couldnt fix the fan coming on with key off problem. turned key off and on several times without starting it to test other things headlights stero etc, everything works fine. . Now car wont crank.
key on i hear a click and dash lights come on. check engine goes out then a few sec. later srs goes our leaving batt and oil park and d4 on turn key over nothing hear some kind of faint electrical noise maybe fuel pump kicking in not sure. no pgmfi light comes up just thought of that. brake light comes on when in crank position. underhood fuses alll good except 15a light fuse interior. interior fuses all good. battery terminals clean and tight tried two good batteries as well.
ignition switch was replaced this summer so its brand new
d4 light no longer on just park so i dont think its the saftey neutral switch
Old Jan 9, 2012 | 08:23 AM
bdmlilburn's Avatar
Default Re: 93 accord wont start all of a sudden
have the following properly tested with a voltmeter or at autozone:
main relay
starter
ignition switch
Sam.R
Feb 11, 2018 09:51 AM
Msreahawn2
May 7, 2017 11:41 AM
londonsupra
Feb 13, 2007 08:34 AM
slickrc
Mar 2, 2006 08:54 AM
labatt50
Jan 23, 2006 07:49 PM
