Rear drivers side door wont open
Old Jan 8, 2012 | 07:03 PM
97whiteciviclx's Avatar
Default Rear drivers side door wont open
Just got my first Honda and I love it. I saved 2 additions from my previous car, rear speakers and the subs. I installed the speakers and purchased a new deck for my Honda. Only problem is that I am having difficulty running the wire to the trunk because my drivers side rear door wont budge! At first the lock wouldn't budge, but after I removed the door panel a pulled on the lock, it now works, with the power locks as well. It just seems that the door latch isn't turning and I don't know exactly what to do. I spoke with my supervisor at my job who knows about this supposed infamous problem with late 90's accords and civics. I was told that there was a certain point I need to drill lock and have it disengage, but am not quite sure where to start or if that is even accurate, is there any advice in opening the door? I will purchase a new door latch as soon as I find a reliable source such as a website or a walkthrough. Thank you for your time and a happy new year to you all!
-97
Old Jan 9, 2012 | 12:01 AM
xjoewhitex's Avatar
Default Re: Rear drivers side door wont open
Pull the door panel off again and pull the linkage that opens the door. I'd assume the probably will be obvious if you look.
Old Jan 9, 2012 | 05:47 AM
The panel is still off and I have pulled the link many times, nothing happens. The spring still works when I let go and the linkage goes back into place, but the door stays closed. I even stuck my hand into the door and lifted the white plastic piece (which I presume will have to be the next piece that I remove in order to open the door) and nothing happens. I need to pick up some piece from a junkyard and replace the lock, I just don't want to drill the door and not be able to replace it and have to buy a new door.
lp20th
Jan 3, 2015 07:27 AM
sarahf
Honda CR-V & Element
Jul 21, 2014 06:50 AM
thomas998
Feb 2, 2010 07:45 AM
jdmed3
21
Mar 13, 2009 01:17 PM
Jonathan_ED3
Jan 12, 2005 01:37 PM
