1000cc injector question.
Old Jan 8, 2012 | 06:29 PM
dk=gsr's Avatar
Icon2 1000cc injector question.
Ok here is the deal, im planning on making 300-380hp on 1000cc injectors.
and im running a gt35R turbo with 3indownpipe and later in the future is planning to go bigger with better internals and more boost. Just want to buy it and run it now so i won't have to switch it out later...
Old Jan 8, 2012 | 06:31 PM
TheShodan's Avatar
Moderator
Default Re: 1000cc injector question.
And your question is................................................ ....?
Old Jan 8, 2012 | 06:34 PM
sanman000719's Avatar
exactly
if its can i make that power on them then yes yes you can
Old Jan 8, 2012 | 06:35 PM
dk=gsr's Avatar
oh yea the question was, Can i run the 1000cc and be fine or is it too big???
Old Jan 8, 2012 | 06:37 PM
4cylfiend's Avatar
If you question is "Can I make 300-380whp with 1000cc injectors?" The answer is yes.
You can achieve that on pump gas or e85. Depending on your plans for "going bigger" you may need more injector in the future.
My Injector Dynamics 1000's maxed out at 521whp on e85.
Old Jan 8, 2012 | 06:41 PM
dk=gsr's Avatar
yea just planning to run it on pump gas, but i also heard that running it e85 would be safer because it cools down the cylinders?
Old Jan 8, 2012 | 06:43 PM
wow must be a pumpm issue because ive made 650 on rc1000's and e85
the 1000's are fine man, and will give you the opertunity to make more power in the future
Old Jan 8, 2012 | 06:48 PM
4cylfiend's Avatar
Interesting.. It may be pump related because I'm running an a1000 and they dont like high base pressures. I just went ahead and bought ID2000's
Old Jan 8, 2012 | 06:52 PM
dk=gsr's Avatar
thanks guys.
Old Jan 8, 2012 | 06:54 PM
umm im on an a1000 at 70psi base man been like that for 3 years.
is this what your being told or just think out of caution
Old Jan 8, 2012 | 06:55 PM
OP no problem man
Old Jan 8, 2012 | 06:56 PM
rico892002's Avatar
interesting...sanman000719 what pump was u running and fuel pressure?
Old Jan 8, 2012 | 06:58 PM
a1000/rc1000/e85/base was 70psi its maxed out now at 600, and duty is 98%
Old Jan 8, 2012 | 07:32 PM
rico892002's Avatar
hmm wonder what i can do on pte 1200 and walbro 255 or or walbro 400 on the e85
Old Jan 9, 2012 | 04:47 AM
4cylfiend's Avatar
We tried using different base pressures but by the time we started raising it to 90+ psi it wasnt keeping up. It was adding another 26lbs of fuel on top of that since its boost referenced at 1:1.
I was suprised that they ran out of fuel so fast myself since I had seen people making 600 on ethanol.
Old Jan 9, 2012 | 04:54 AM
4cylfiend's Avatar
Rico- You will be able to make your power goal on the 1200's.
Btw, I thought you were running (2) 255's?
axelintegra
Apr 26, 2010 05:17 PM
95BoostedEJ1
Engine Management and Tuning
Nov 17, 2009 12:05 AM
