Suspension & Brakes Theory, alignment, spring rates....
power steering conversion
Old Jan 8, 2012 | 05:45 PM
b16bri's Avatar
Default power steering conversion
Hey guys i have a 96 civic with out power steering what parts are needed/ how hard is it to convert it to power steering.
Thanks
Brian
Old Jan 8, 2012 | 06:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: power steering conversion
Never heard that one asked before.
https://honda-tech.com/forums/showth...power+steering
Old Jan 8, 2012 | 06:59 PM
confidence's Avatar
its very easy. Just plug and play really. Having a lift makes it even easier.
You need the proper pump for your engine, the power rack, the U joint that connects the rack to the steering wheel rod, and the hoses.
There is a sensor on the one of the lines that is for line pressure. I think it just kicks a light on when you have low fluid. Since you didn't have PS already you simply won't hook this sensor up. Hook it all up, fill with fluid and get and alignment and you are finished. Its that easy
Old Jan 9, 2012 | 09:16 AM
b16bri's Avatar
ok cool thanks a lot and i can get these parts from any 96-00 civic including 99 si any civic that has power steering
Old Jan 12, 2012 | 06:05 PM
confidence's Avatar
get the same pump and mounts you have in your car.
No subframe is necessary. The EKs all have the same subframe.
here is a write up. i had forgotten existed when i first answered your question
http://repo.jackmoves.com/v/erik/album106/album119/
clewis152
Aug 7, 2012 05:01 PM
b16bri
Jan 10, 2012 06:19 AM
DarkBB4
Dec 8, 2007 08:10 PM
ahron
Jul 18, 2007 03:50 PM
bdubnyc
Jun 15, 2007 05:53 AM
