Need the end connector for the speed sensor wire..
Old Jan 8, 2012 | 03:11 PM
FrontwheelENT's Avatar
Default Need the end connector for the speed sensor wire..
Got a 96 ek 5spd. Hey, my speedometer isnt working so i went to check out the connection. I noticed that the previous owner had cut the wiring of the speed sensor. The sensor is there but the 3 wires that go into the sensor are cut. I need the CONNECTOR that those 3 wires are plugged into so I can then put that CONNECTOR into the speed sensor. I DO NOT need the speed sensor, just that connector for those wires, where can i get this?
I need the grey piece in this pic...
Old Jan 8, 2012 | 03:39 PM
Former User's Avatar
Default Re: Need the end connector for the speed sensor wire..
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Jan 8, 2012 | 03:44 PM
hannslebo's Avatar
Junkyard for the gray connector and splice the wires in.
guessohw
Nov 11, 2011 02:50 PM
xalents23
Jun 3, 2008 07:59 PM
aho
Feb 21, 2007 12:49 PM
enabi
Jun 19, 2002 07:54 AM
