Camber kit question.
I am going to replace my ball joints and bushings. So I thought maybe it would be easier, and pretty economical, to just go with a camber kit. (To save some headache for UCA's anyways.) However, my question is, does anyone know if any of the kits come with bushings pre-installed, or will they be seperate, requiring the stock housing?
The bushings aren't part of the UCA on the front of a 3rd gen Integra. They're in their own subframe which bolts into the chassis, then the UCA bolts to them.
A camber kit will not save money here. Alignments will be more expensive with the aftermarket part, and if they ever slip you'll be paying for alignments more often too.
Do you know of a good UCA replacement option that includes the balljoint, bushings, and subframe? I'm just looking for options, the parts are off the car right now and I have already tackled the LCA's. However, the method I'm using to remove the bushings will not work for the uppers...I thought of this because for the money I thought it wasn't much more than a good set of balljoints alone, and if it's all ready to install as one unit, why not? Thanks
Kwalsh24
Aug 20, 2006 02:12 PM
