is this why honda went to 5-lug for the R?
"2002-09-07 Spoon Sports/Inline Four TOR competed in NASA's 2.5 hour endurance race at Willow Springs International Speedway. Although TOR competed, TOR was unable to finish due to 3 broken wheel nuts while going 130+ mph on turn 8. "
http://www.teamorangeracing.com
wow
you guys just do endurance?
i think that car would be awesome in the tcra 2.2 liter challenge!
[Modified by EPGONZALEZ, 3:15 PM 10/8/2002]
Dumb Question
What exactly is the reason for extended studs?
What do they do?
And how would thye and open lugs help in this situation?
What do they do?
Dumb Question
What do they do?
What do they do?
Doubt they would've helped, unless they were made from a stronger metal or being longer would help distribute some of the weight on 'em. *shrug*
I understand you were kidding, and that it is the rules when you go below a certain ET. But my question is WHY?
If they make it a rule, they must have a reason....what is the reason?
wow...that is nuts.....like someone said earlier, 5 lugs disperse torque a little better, but, why haven't i ever seen that happen to a itr, or other 5 lug suspensions
i personally dont think the speed and turning alone did it...
maybe a little loose or vibration?
something else maybe..but the again...
willow turn 8-9 are pretty fast
I'm sure R's also have heavier duty hubs than their counterparts, which will also take the heat/stress better. Neons had a big problem with their hubs dying and the R/T or whatever versions had better hubs and no extra lug. :D
