Bad turbo cause knock sound???
Old Jan 7, 2012 | 08:12 PM
1slowcrx's Avatar
Default Bad turbo cause knock sound???
I know for sure my turbo is bad but I'm tring to eliminate the possibility of a block problem. Car drives fine but low on power due to turbo? My question is, can a turbo have so much play that it will cause a sound similar to a rod knock on start up after sitting? Not consistent, goes rite away. But can also hear it at low steady idle sometimes. The turbo has alot of play up and down and in and out.
Old Jan 8, 2012 | 11:15 AM
TheShodan's Avatar
Moderator
Default Re: Bad turbo cause knock sound???
No. It not enought to hear through the bay. But if you keep driving with it that way you WILL break something off and possibly destroy what's left of your engine.
TURKISHFORCE
Feb 23, 2011 07:33 AM
sohcvtec66
Oct 2, 2005 07:20 PM
brixity
Apr 28, 2005 08:47 AM
95cxhatch
Mar 8, 2005 07:27 PM
DjFreeze
Jan 14, 2003 02:24 PM
