5 or 6 17 mm bolts honding a ef trans to block?
Old Jan 7, 2012 | 04:31 PM
graveltravel2's Avatar
Default 5 or 6 17 mm bolts honding a ef trans to block?
trying to do a clutch job myself but I cant seem to pry the trans off of the block.
I pulled out 5 bolts that connected the trans to the block.all my buddys said theres only 5, but i saw on here that somebody said theres 6.
i looked and looked and cant find shiz.
ive been hammering screwdrivers to seperate the trans from the block and no luck.. job was kinda easy until this shiz...
one buddy said it could be a rusty imput shaft. and another said that it must be in reverse to come out, but another buddy said that it doesnt matter what gear its in to come out....
any help would be great.
Default Re: 5 or 6 17 mm bolts honding a ef trans to block?
excuse the poor grammer and spelling. ive been up since 4 am and been working on this car since 3 pm.
Old Jan 7, 2012 | 05:03 PM
crvtectim's Avatar
Have you removed the starter?
Old Jan 7, 2012 | 05:08 PM
JOE BD-0's Avatar
There is one bolt that faces the opposite direction than all of the others. It is near the shift linkage on the trans. Good Luck.
Old Jan 7, 2012 | 05:13 PM
bgdriver's Avatar
yup 6 bolts.
Old Jan 7, 2012 | 05:17 PM
Jockone's Avatar
I think you are missing the bolt that comes through the enging into the tranny around where the axle is.
Old Jan 7, 2012 | 05:26 PM
heres what i got..
the one buy the front mount close to the radiator fan
the 2 above that
the 1 by the starter
the 1 above the axle the backside. going from motor to trans.
wheres the 6th????
Old Jan 7, 2012 | 05:37 PM
Jockone's Avatar
One starter bolt goes into the engine.
Do you have the dust shield off from underneath the car?
And lastly the trans may be stuck on the dowel pins.
Old Jan 7, 2012 | 05:50 PM
yes ofcourse the starter is off and the flywheel "dust cover" is off as well..
but somebody said yes theres 6 bolts... what am i missing?
and i heard that the imputshaft could be rusted causing it to seize.
does it have to be in a certain gear aswell?
Old Jan 7, 2012 | 05:58 PM
Jockone's Avatar
I was just asking about stuff to try to help you.
I just went and checked a D series in my garage and got 5 17 mm bolts plus the starter bolt.
Gear you have car in won't make any difference at all
It is possible that the input shaft could be rusted to the clutch disc and that could be stopping the trans from coming off.
Last thought is have you got the rear mount bracket unbolted?
Old Jan 7, 2012 | 06:08 PM
yup rear mount is unbolted.
Old Jan 7, 2012 | 06:14 PM
Jockone's Avatar
Then I think you have everything unbolted and tranny should come off.
Old Jan 7, 2012 | 06:26 PM
hahah easier said than done.....
i gave up a few hours ago and gonna try again tommorrow.... im starting to hate ef's.
Old Jan 7, 2012 | 08:02 PM
sde780's Avatar
5 bolts. You should try jiggling the clutch release arm, that was what held mine together for some reason
Old Jan 8, 2012 | 06:06 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
No, it's always easy when you know what you are doing. EF's are the simplest to work on... Sell it if you hate it so someone else can enjoy it. Have you trying using a pry bar? How about a jack to stabilize it? Something that can happen on ALL vehicle with manual transmissions is the input shaft splines can rust to the clutch. So you can't even split it or you can't get it to come off?
PS - Bad grammar has nothing to do with being tired or drunk for that matter. Typically you have it to begin with - apology accepted.
jhof_wagon
Dec 14, 2012 12:29 PM
chriscool888
Jan 9, 2011 09:54 PM
sammyb20
Mar 1, 2009 07:30 PM
Soon2bH2b
Welding / Fabrication
Sep 25, 2007 03:32 PM
mikeycivic
26
Jan 2, 2007 02:37 PM
