CAI less gas mileage??
Old Jan 7, 2012 | 08:06 AM
bryan24207's Avatar
Default CAI less gas mileage??
i just installed a cold air intake that goes down just in front of the tire, but it seems like my gas mileage went down, what could be the problem????
Old Jan 7, 2012 | 08:11 AM
Gsrsi's Avatar
Default Re: CAI less gas mileage??
Heavy foot.
Old Jan 7, 2012 | 08:33 AM
grumblemarc's Avatar
The Grumpiest
You're imagining things.
Old Jan 7, 2012 | 08:53 AM
bryan24207's Avatar
no not imaging anything, i usually get just under 400 miles to a tank, had to fill up today at 320 miles on this tank..idk it might be something else..im gonna do my head gasket and clean my IACV next week hopefully..it might just be my foot got heavier but i dont know
Old Jan 7, 2012 | 10:07 AM
GagnarTheUnruly's Avatar
It's just one tank. There's no reason adding a CAI would change fuel econ.
Old Jan 7, 2012 | 10:09 AM
bryan24207's Avatar
maybe i got some crappy gas...ill find out on this tank i guess..also whats some more mods i can do to get better gas mileage? im trying to make a super high gas mileage car here bc i drive ALOT
Old Jan 7, 2012 | 10:13 AM
The Grumpiest
Take the damn intake back off and restore it to stock.
Old Jan 7, 2012 | 10:15 AM
sebTeggy's Avatar
Why are you doing a headgasket change? For fun? I hope it has failed.... Don't do a headgasket on maintenance intrevals... Unless you are taking the head off for whatever reason
CAI should improve economy. You probably have a heavy foot. My milage also varies 5 MPG seasonally. Especially if I warm my car up and start it a lot.
Old Jan 7, 2012 | 10:16 AM
actually i think a CAi might actually improve econ slightly by removing a flow restriction. best way is with driving habits, however. not many mods will increase fuel econ, although all-motor mods that dont alter displacement dont seem to hurt
Old Jan 7, 2012 | 10:17 AM
oops too late. 1hand typing FML so slow
Old Jan 7, 2012 | 10:23 AM
bryan24207's Avatar
my headgasket didnt go fully yet, but its leaking out oil on my block so i wanna do it, gonna put arp studs in while im in there as well..
Old Jan 7, 2012 | 10:34 AM
The Grumpiest
Wait. So your headgasket has issues and you're wondering about a CAI? YOu don't think THAT might have something to do with it?
Old Jan 7, 2012 | 10:38 AM
bryan24207's Avatar
my head gasket has been like that since the day i bought the car, the car always had cam seal leak, (fixed) vcg leak (fixed) i just am waiting for my head gasket set and arp studs to come in so i can do the job, its not leaking worse or less than it did. but i noticed the slightly less mileage rite after i did the intake, and as for stuff to get better gas mileage couldn't i go with different tranny or gearing to have less rpms when on the highway to improve it?
Old Jan 7, 2012 | 02:56 PM
imbest123's Avatar
head gasket blown thats leaking oil? i highly doubt that.
the cai should theoretically improve mileage but considering that your ecu is probably doing some minor adjustments and adding more fuel into your motor then that could be your issue but even then the difference is so minimal that you shouldnt have even noticed a mileage difference unless youre giving it more gas through the pedal.
i say its your driving.
also, as mentioned above, winter gas burns faster than summer gas so that could be another factor
Old Jan 7, 2012 | 03:00 PM
bryan24207's Avatar
well i already replaced my valve cover gasket, and cam seal because they were leaking, and the only place i see oil anymore is where the head connects to the block. i might be a noob on this forum but i'm not a noob too cars
Old Jan 7, 2012 | 03:52 PM
beaterman's Avatar
check your distributor o ring first.
Old Jan 7, 2012 | 03:55 PM
doood's Avatar
been there done that
throw a d15 in there. 40+ mpg ftw.
Old Jan 7, 2012 | 03:59 PM
DirtyDA9's Avatar
Does the intake have little "bungs" to hook the vacuum lines back up? You may have left some unconnected.
Old Jan 7, 2012 | 04:05 PM
el crapitan's Avatar
man, you guys. a CAI introduces denser air into the combustion chamber. denser meaning more o2 molecules per cc. your o2 sensor reads the oxygen level in the exhaust and relays it to the pcm. the pcm then adjusts fuel injector duration accordingly.
simply put-denser air=more fuel
it's the reason why this is not considered "free" horsepower. it's also the reason why mileage stinks during the winter
to the op, you want better mileage, maintain what came from the factory well and you're set
Old Jan 7, 2012 | 04:10 PM
bryan24207's Avatar
all the vacuum lines are still connected it had the bungs for the hoses, and how do i check the distributor o ring? just pull off the dizzy?
Old Jan 7, 2012 | 04:11 PM
bryan24207's Avatar
its funny you said that, i was considering putting a d15 into it..but wouldnt i lose my heat, ac and ps? i love having all that as i have a wife n 2 babies
Old Jan 7, 2012 | 04:14 PM
by cam seal, you mean the plug? if not, it's probably coming from there.
just hose it all off with brake clean. everything. get it spotless. then just run the car and watch with a flashlight to see where it's coming from. it aint rocket surgery
Old Jan 7, 2012 | 04:21 PM
bryan24207's Avatar
no i mean the cam seal, that cheap shitty plastic piece of crap, it was leaking when i got the car, now i got the aluminum BLOX cam seal in and its NOT coming from there..
Old Jan 7, 2012 | 05:16 PM
that's not the cam seal. it's the plug.
but yea, just hose it down with brake clean. all spotless. then run it and watch with a flashlight.
Old Jan 7, 2012 | 05:18 PM
bryan24207's Avatar
then why does EVERYONE even the place i bought it from call it a "Cam seal"
