Momo horn button with after market horn, where did I go wrong? Pics inside.
I followed this:
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-wire-horn-nrg-short-hub-2402541/
And the pics..
Inserted the power wire in the correct slot according to the article and hooked up the ground supplied with the hub.
Uploaded with ImageShack.us
And the orange horn plug for my autozone horn.
Autozone horn with ground connected and open prong for horn plug..
And the pics..
No blown fuses or any melted wires just can't get a honk out of her.. I got this car with no horns and no horn button just the wheel and quick release. Also the instructions that came with the autozone horn talks about a one and two horn setup and I'm just trying to get away with one on the driver side. Seems like it should be a straight forward job.
Both connectors hook up to the horn. The horns don't ground through themselves, they ground through the horn relay.
That makes sense according to the diagram in my Haynes manual but the only other wires I can find are the other red/blue passenger side horn wire and a solid black wire next to it located near the passenger blinker
I checked out this diagram but no sign of a white/green wire only blue/reds
and this is on the pass side where I found the other b/r wire paired with this black wire from behind the turn signal.
It's been a while since I did a horn, so I'm probably remembering wrongly about the two connectors.
You likely have a single connector with two wires, but one of the wires is missing. Are there two conductors in the front of the connector?
Either way, you have the wiring diagram with wire colors and power distribution, so you should be able to work this out. Unless somebody's monkeyed with the wiring and cut the wht/grn wire off...
Those after market wires are for the hid's i had then done but I have looked everywhere and don't see a w/g wire I even cut back the wire shroud and no cut wires I keep searching for a location of the w/G wire but no luck im guessing its been ripped out..
In the diagram it looks like the w/g comes from the horn relay, and the underhood fuse box as well. Find the w/g wire coming out of those and trace it from there to find where it ends and where it's hiding lol
