Need Helms for 96 F22B2 Accord
Im looking for a helms for the F22B2 96 accord.
If anyone has one or can answer what color are the wires for the tps, egr, and map sensor.
And Also if the map sensor is located on the firewall and is separate to the engine wire harness that would be good.
Also does what colors are the dizzy wires, and if the oil pump has the TDC sensor in the oil pump.
Thxs in advance
Thxs in advance
thought I downloaded the 96 version of it, but it came to me kinda weird and I didnt understand it. It was saying that all 3 sensors are in the dizzy for CKP,CYP and TDC.
But since its OBD2 shouldnt 2 of the sensors be in the fuel pump? I found the wires that match the general OBD2 CYP and TDC going to the oil pump, but I found a 2 wire plug up near the dizzy where the wire colors are Blu/grn and blu/yel which would equate the obd1 wiring, so Im not sure what it is. And it doesnt help not having the car in front of me either, and I didnt take it off the car as well.
So if you can help me with that, it would be great.
Last edited by TouringAccord; Jan 10, 2012 at 04:02 AM. Reason: cleaned to remove links to downloadable copywritten material
The OBD2 connector with BLU/GRN & BLU/YEL wires is the counter shaft speed sensor located on the back of the transmission. (Close to the distributor/thermostat)
If you have the 94 Accord helms and combine it with the 96-97 Mitchell wire diagram, also found on that site. You have everything you should need to trace wires.
Yes the TDC for the OBD2 is located on the oil pump housing along with the CKP. Behind the TB cover.... The cylinder position (CYP) sensor is the only one in the distributor. With the external coil F22B2 the CYP wires are the BLK & YEL wires coming out of the distributor housing.
So thank you very much. I think I got the rest from here.
