what and where is a oxyegen sensor heater
Old Oct 8, 2002 | 12:25 PM
GRAVEDIGGER's Avatar
Default what and where is a oxyegen sensor heater
code 65 how do i trouble shoot this and find the problem,i am positive sensor is still good just got wet from steamcleaning, anyone
Old Oct 8, 2002 | 12:28 PM
B_CRUZ!'s Avatar
Default Re: what and where is a oxyegen sensor heater (rp2000r)
if you have a four wire o2 sensor then it is heated. two of the wires heat the sensor...
Old Oct 8, 2002 | 12:37 PM
Default Re: what and where is a oxyegen sensor heater (B_Cruz)
yes it is a 4 wire and what color wires are the heated ones and how to fix or diagonose ,car is a 96 hatch all stock and i think water fouled sensor about a month ago when i cleaned the engine.throwing code 65 ,need to fix asap . any help is appreciated
Old Oct 8, 2002 | 12:42 PM
B_CRUZ!'s Avatar
you have to replace the sensor...
Old Oct 8, 2002 | 12:52 PM
are you sure.car was throwing codes 17,41.65 replaced alternater sp sensor fuse and it cleared codes 41,17 but still have 65.does the sensor just burn out like that or is there a fuse to check thanks. if i need new sensor where to buy one for cheap?
Old Oct 8, 2002 | 01:05 PM
also is it just the 02 heater that is screwed up or the whole o2 sensor
Old Oct 8, 2002 | 01:26 PM
Briman2021's Avatar
I would just get the universal one from napa or checker, it is only $60, but you have to find wiring diagrams so you know which wires to connect. The one from honda for my car (97 civic ex) was around $250 - $300
Old Oct 8, 2002 | 02:04 PM
PhuckinHondas's Avatar
Default Re: what and where is a oxyegen sensor heater (Briman2021)
you have a heated o2 sensor
the whole sensor has to be replaced
obd2 and some obd1 cars have these to help the car get into closed loop faster to help the emission levels stay low
so basicly you have to get a new sensor ...80bucks big deal
Old Oct 8, 2002 | 02:11 PM
B_CRUZ!'s Avatar
Default Re: what and where is a oxyegen sensor heater (In The 16s)
not even $50
http://www.oxygensensors.com/
get the one for a 94+up integra 4 wire.... direct plug in....
vrotsos991
Honda Civic (2001 - 2005)
13
Nov 14, 2011 06:31 AM
craigmack14
Nov 2, 2009 05:08 PM
adude2003
May 29, 2008 03:06 PM
breathinez
Aug 18, 2004 09:20 AM
