01 prelude wont start getting spark injectores wont fire
Old Jan 6, 2012 | 12:56 PM
mtdelsol's Avatar
Default 01 prelude wont start getting spark injectores wont fire
i just picked up this 01 prelude 5 speed with no start guy i picked up from blew trans replaced trans and now wont start he said he checked grounds he made a decent after market grounding harness said it had spark but no fuel i here the pump prime there is voltage at injectors and also i checked the compression what would only stop the injectores i could only think ecu and maby a fried ground
on a side note there is a large connector with like 15 wires connected to trans mount in back that nothing is hooked too if need pics i can get em
Old Jan 6, 2012 | 12:58 PM
mtdelsol's Avatar
Default Re: 01 prede wont start getting spark injectores wont fire
forgot to post there are no check engine lights on
Old Jan 7, 2012 | 06:48 PM
mtdelsol's Avatar
Default Re: 01 prelude wont start getting spark injectores wont fire
after checking all the sensors and all coming back positive i decided to see if it was flooded held peddle to the floor crank it over for 10 to 15 seconds and it started up rough at first but cleared up runs great also found out it has a brand new trans from syncrotech +++ well rebuilt no lsd
so it was either flooded or air in the fuel system
Old Jan 7, 2012 | 07:15 PM
P. Hunter's Avatar
welp looks like you fixed this with no help!!! good job
si_motor_spt
Aug 17, 2022 10:52 AM
Raevyn67
Aug 23, 2013 01:42 PM
B and B
Aug 20, 2008 06:15 PM
same ol' civic
Jun 5, 2005 07:29 AM
bonestock92si
38
Aug 30, 2004 10:02 PM
