HELP: GsR motor into Crx
Old Jan 5, 2012 | 11:40 PM
EF8DayDreamer's Avatar
Default HELP: GsR motor into Crx
im picking up a 94 Gsr motor next week. the motor wont go in until everything is straightened out but either way im picking it up. i already have an LS b18a1 obd0 in it. my question is besides the obd0 to obd1 conversion harness and the ecu is there anything else i would need.
Old Jan 6, 2012 | 12:57 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: HELP: GsR motor into Crx
I'm pretty sure everything you need can be swapped over, but double check your homework on the drivers side mount (engine -> mount). You'll also have to wire in VTEC and the IAB stuff (if running stock gsr intake mani). What swap mounts are you currently running?
Also, be prepared to cut the webbing or space your hood as the GSR is a bit taller than your current LS.
Old Jan 6, 2012 | 02:56 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You need to use the LS post mount on the driver's side.
I assume you are keeping the cable transmission and just swapping engines? If not, that changes quite a few things.
Old Jan 6, 2012 | 06:40 AM
whited's Avatar
CRX God
I am a bit confused here. Even if the bracket that goes to from the engine to the motor mount is different. Can't he just swap that bracket between the engines, and still use the other motor mount?
This is only if you have hasport mounts, some other mounts do not require this change.
Old Jan 6, 2012 | 06:45 AM
213374U's Avatar
0x5359-0055
Community Builder
That's why I simply told him to check the drivers mount as I remembered having to do something different when I swapped mine. Same when I asked what mounts he's using.
Old Jan 6, 2012 | 08:00 AM
ef yu's Avatar
all the accessories can be used from your obd0 engine to run your obd1 gsr.
dont forget to change the obd0 post mount over to the gsr engine as the mounting location for the mounts will be different.
Old Jan 6, 2012 | 08:31 AM
HondaPartsHero's Avatar
Technical Hero
You'll also want an OBD0-1 distributor adapter if you don't already have one. Plus wiring for VTEC, knock and IAB's. What ECU are you going to be using?
Old Jan 6, 2012 | 07:35 PM
im using 1st gen hasports. im eventually going b16 tranny. im going to be using p78.
Old Jan 6, 2012 | 07:36 PM
which conversion harness is recommended?
Old Jan 6, 2012 | 08:45 PM
213374U's Avatar
0x5359-0055
Community Builder
I'm running the Boomslang with zero issues.
Old Jan 7, 2012 | 12:57 AM
codybuRr's Avatar
GSR in an EF is the tightest fitting bseries yo!
Old Jan 7, 2012 | 08:30 AM
DO IT ON ALL FOURS
No, I am pretty sure a COMPLETEY stock B20 would be.
Old Jan 7, 2012 | 11:10 AM
Its worth the swap all day lol so I don't need anything other than the wire harness ecu the dizzy adapter ?
Old Jan 7, 2012 | 01:25 PM
codybuRr's Avatar
well, at least a b20 with an LS manifold isn't tight, stock b20 everything doesnt fit!
Old Jan 7, 2012 | 09:24 PM
could i hood prop save me from cutting since im using hasports
Old Jan 7, 2012 | 09:47 PM
213374U's Avatar
0x5359-0055
Community Builder
I propped mine ever so slightly. Not a fan of jeopardizing the structural integrity of my hood considering I've had at least 3 close friends have it fly up doing better than 55mph.... didn't turn out so well for them.
Old Jan 7, 2012 | 09:54 PM
yea thats happened to me before. hood wasnt shut right. my wire harness is cut, how should i go about this?
Old Jan 7, 2012 | 10:05 PM
213374U's Avatar
0x5359-0055
Community Builder
What do you mean "is cut"?
Old Jan 7, 2012 | 10:29 PM
clips are cut. its an ugly looking engine harness.
Old Jan 7, 2012 | 11:08 PM
213374U's Avatar
0x5359-0055
Community Builder
Could just pick up another harness. I wish I had done this when the GSR was still out and on the pavement so I could re-route some of the wiring and tuck most behind the block up under the IM.
Old Jan 10, 2012 | 07:34 PM
can i use a stock crx si harness or should i grab gsr harness or does it even matter?
Old Jan 10, 2012 | 07:35 PM
the motor is coming with the iabs intake manifold but im getting rid of that ****.
Old Jan 10, 2012 | 07:36 PM
and the distributor was rewired to obd0 or some **** like that.
Old Jan 10, 2012 | 07:59 PM
bmxtrev's Avatar
you need to convert the distributor as well.
Old Jan 10, 2012 | 08:07 PM
the dizzy is obd1 but it was rewired to obd0 unless i heard him wrong. but what you mean convert the distributor, you mean with the adapter that comes with the jumper harness?
