need help w/'02 Accord Coupe tail light lens
Old Jan 5, 2012 | 10:22 AM
92 Accord...man's Avatar
Icon6 need help w/'02 Accord Coupe tail light lens
can anyone tell me how to install these, as to get just the upper turn signal, and NOT the upper running light. I would appreciate all/any help. thanks.
Old Jan 5, 2012 | 08:15 PM
75aces's Avatar
Default Re: need help w/'02 Accord Coupe tail light lens
Pull the trunk carpet back in front of the turn signals. You may have to remove a plastic cover to open the carpet.
Old Jan 6, 2012 | 05:10 AM
Installation is child's play...what I'm after is how to get the upper bulb to function ONLY as a turn signal and NOT as a running light...so it's just an electrical question. This maybe a no-brainer to most, and I could probly mess around with the wiring, but I don't want to fry anything...ie...fuse, bulb, etc. Is it just as simple as unplug one of the wire leads? or a single filliment bulb vs. a dual filliment??? Anyone know what I'm after??? thanks.
Old Jan 6, 2012 | 09:17 PM
75aces's Avatar
Found this method. The guy used a trailer setup for his motorcycle. Maybe can get better ideas from here. Hope it helps. http://roadstarclinic.com/content/view/17/103/
Old Jan 7, 2012 | 07:47 AM
Icon2 Re: need help w/'02 Accord Coupe tail light lens
Wow, that sounds way to complicated, I read somewhere that all ya need to do is tape off the leads on one of the bulbs? not sure where that was or which bulb??? ANYONE else know what I'm after???? thanks.
Old Jan 7, 2012 | 02:24 PM
75aces's Avatar
That's what I googled last night. I'll see what else is out there.
no_skillz
Lighting
Jan 17, 2012 11:53 AM
1989accordlxi
Classic Hondas
Mar 19, 2008 02:27 PM
blktrailblazer
Sep 27, 2007 03:47 PM
civicboisi
Jul 26, 2006 02:43 PM
