Need Help 4x114.3 ITR Brake Conversion in 95 Integra GSR
Old Jan 4, 2012 | 04:52 PM
deary09's Avatar
Default Need Help 4x114.3 ITR Brake Conversion in 95 Integra GSR
Hey guys, i just bought a jdm 96 integra type r 4x114.3 Disc Brake Conversion but can't seem to find a company that sell any rotors for it. Please let me know if you did this to your integra and what brake rotors you got and did. Thanks
Old Jan 4, 2012 | 06:39 PM
highroller54's Avatar
Default Re: Need Help 4x114.3 ITR Brake Conversion in 95 Integra GSR
fastbrakes sell some redrilled, bored rotors that fit.
el crapitan's Avatar
for the fronts? you can swap in 93-96 prelude sr-v rotors and calipers. 11.1"
one of the reasons i swapped to 4x114 myself
your other options are to get ls rotors and have them re-drilled, or re-drill them yourself.
fastbrakes also makes rotors for these hubs
edit: oops just saw the post above
Old Jan 4, 2012 | 07:40 PM
deary09's Avatar
ok, what do you recommend to do for a cheaper price?
Old Jan 4, 2012 | 07:42 PM
deary09's Avatar
maybe get ls brembo drilled slotted rotors and get it drilled to 4x114?
Old Jan 4, 2012 | 08:06 PM
^^yea, you can do that. but i would get blanks. should be cheaper, and are a lot easier to machine when the time comes
Old Jan 4, 2012 | 08:09 PM
deary09's Avatar
i'ma get the drilled slotted one and have a shop drilled it to fit 4x114. I don't mind spending $200-$250, and not willing to spend 800 bucks just for the front from fastbrakes lolz
Old Jan 4, 2012 | 08:18 PM
800$ for rotors? no no no. there must be a mistake. that is retarded.
you can get brembo blanks for like 120$. or maybe at least just go with slotted. you'll be sorry with the cross-drilled when it comes time to have them machined
Old Jan 4, 2012 | 10:56 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
What's the advantage of the 4X114.3 conversion? The brakes are the same size as the GSR. It's just harder to get rotors.
I'm fairly certain that you can use 92-96 single cam Prelude rotors. Bring one home from the parts store. Try to fit it on. If it fits...SUCCESS!! If it doesn't, then bring it back.
Old Jan 5, 2012 | 06:30 AM
the advantage is wheel selection. plus the fact that you can utilize prelude sr-v 11.1" rotors/calipers. just have shave a couple mm off the carrier. i'd imagine same goes for the single cams, though i'm not positive
Old Jan 5, 2012 | 08:45 AM
B serious's Avatar
If you use a 11.1" rotor, you'd have to get the 97+ spec ITR/CTR 5 lug calipers/brackets, IIRC.
Old Jan 5, 2012 | 09:42 AM
you can use sr-v calipers. just need to shave a couple mm off the carriers
did it before. was thoroughly impressed with the stopping power
Old Jan 5, 2012 | 02:36 PM
B serious's Avatar
You used 96 spec ITR calipers and brackets and 11.1" rotors? How? 96 spec rotors are 10.x", arent they? BTW, the SR-V doesn't exist in the US. I'm not familiar with that model.
deary09
Jul 26, 2012 06:11 PM
trepteg
Jun 24, 2009 07:34 AM
noopsITR
Jul 7, 2007 01:52 AM
black cx
Suspension & Brakes
Jul 12, 2005 06:36 PM
