**LS/gt30 ready for high boost..4sale/trade4 coilovers **
Hey Hondatech! I am trying to part with my built LS block and/or gt30r.
The block is an Ls - b18a1 with eagle rods, JE 9:1 81mm pistons, ARP rod bolts, ARP head studs(still in box brand new) , a GSR girdle that has been line honed, and the block was machined down a little to up the compression. I have every gasket including the head gasket and all of the others you will need even the oil pan gasket, I have the water pump needed and brand new timing belt as well. (EVerything's brand new btw).. I have the golden eagle sandwich plate which is brand new with the braided lined connected. I am including pictures I may have forgot a couple of little things but basically this is everything you need to run at high boost/nitrous its ready to go. Just needs a head.
I also have a GT30r ball bearing turbo - no side 2 side shaft play or any of that junk.. I was going to use that on my other B but if someone wants id throw that in for a little more even. I am interested in getting coilovers I want to slam my EJ just a set of function and form or something of that nature. Blocks in excellent condition and like I said shes ready to go. I ve seen similar set ups making very good power. I would like to see 850 OBO for the block just trying to get me some coilovers really. Located in Chicagoland I can work thigns out though. PM me and I can give you my phone number NO LOWBALLER$! I wont even reply ok. Here are a few pics
Uploaded with ImageShack.us
IemSpooled219
Jan 8, 2012 06:55 AM
Eviltek1989
Mar 21, 2010 05:09 AM
