What exactly has failed? Picture of turbo inside...
The turbo is a Precision SC34. It has around 2k miles on it. I noticed it stopped boosting and thought I had a bad coupling in my intercooler piping. After checking them all I see this...
I assume I am correct in saying that some sort of seal has let go? There isn't any oil anywhere, just soot from the exhaust.
Any idea on what failed?
Is the part replaceable? (If so, how much?)
Will the turbo need to be rebuilt (again)?
I have clocked this before: Could the bolt have just loosened over time (albiet a very short period?)
This could possibly be the death knell for me concerning my build
Thanks for any input
i can't really tell but it kinda looks like the turbine housing has come away from the cartridge. possibly forget to tighten the bolts when it was clocked?
The turbine housing separated from my cartridge and jammed the exhaust wheel into the turbine housing.
3rd vote for Looks like a bolt or two may not have been tightened or come lose when clocking the housing. Check it and see! Hopefully the wheel hasn't made contact with the housing!
If its busted, I just may very well sell the whole thing, if not just sell the car.
Lol these pics hurt to look at.
Op why start a thread with out checking at least your bolts if there loose.
Why start a thread without even taking the damn couplers off and down pipe. Your here hoping someone is gonna tell you exactly what to do when you already know what to do.. start trouble shooting bro.
If its the compressor wheel that separates, the aluminum chips/shavings are going to get into the motor. If its the turbine wheel that takes on damage, everything will be blown through the exhaust.
Correct. Either way, the answer is NO. don't try to keep running the turbo. As you've physically destroyed its ability to move air.
so is it of good measure to use some thread lock. blue locktite on the housing bolts, the down pipe bolts, heck even the head bolts for the manifold? im worried ***** going to loosen up
Ooops lol
I dont think loctite will work on the high temps of the turbine housing. Not sure I never had the problem. Im sure those pics of the housing seperating is the cause of clocking the turbo moving on to setting up the intercooler piping and forgetting to retighten the bolts on the chra
I have used Blue loctite on my manifold studs because I had issues with a few of the nuts coming loose. After applying the loctite I didnt have an issue. I use it on the intake manifold nuts also. Ill probably be putting it on the turbo housing bolts as well just to prevent this from happening to me again.
Loctite might work at that high temperature, but I wouldn't fudge up the threads by using it because it's probably going to get baked. I'd just use lock washers on the bolts.
Ya it does bake up on the threads but it doesnt gum them up to where it will cause damage tot he treads by any means. Its definitely a big cushion from vibrations too.
ummmmmmm LOL those bitches are done.
Because it was about 25 degrees outside and getting dark when I noticed the soot on the turbo. I didn't have the time.
Reference my first answer. I went to work the next day and made the thread first thing in the morning.
I can't say that I've ever faced this problem before. For all that I knew, I had blown the turbo. It didn't even cross my mind until I was making the original post that the housing could be loose. I thought initially a seal or something could be blown and that maybe the part that was blown was replaceable. Many people are much more knowledgeable on this subject than I and I appreciate their help.
Well, yesterday I went out to see if I could get to the bolts without pulling the turbo: I can't (big surprise, I didnt think I could). So I said screw it and played Halo instead.
So I've gotta get time to do that (pull turbo, ect), which since I'm trying to paint my del Sol, I have no idea when that'll get done because frankly I don't want to do it in the first place.
I'll update when I actually do the work (le sigh).
OP if i were you, i'd at least pull the intercooler piping off the turbo, take a light and a camera and snap some photos of the fins while you still have time to make a decision about which direction you want to go...tax season will unveil a ton of deals in the market might be a good time to know if your turbo is done...then you can just source another one and pull it off just one time..
[QUTOTE=mac_24_seven;46626301]My reply in bold. How about not flaming people, eh? Ish happens and this is the first time Ive ever encountered this problem
I'll update when I actually do the work (le sigh).[/QUOTE]
You didnt have time to check the bolts but had time to grab you camera take pics make a thread and play halo????? Am I getting punked???
Take your car to a shop and stop trying to play mechanic.
(j/k)
