MISSING O-RING'S MAP SENSOR AND IDLE SCREW, CAN CAUSE PROBLEMS?
hi Guys, Yesterday i was looking at the throttle body and i found that the Map sensor, and the idle screw dosent have o-rings, can this cause problems in my car?, problems like, low idle, hesistation, missfire??
Most defiantly. With out the o-ring sealing the map to the throttle body, you will not only have a vacuum leak but your map will be getting incorrect readings.
Stupid as this sounds, I was working on my original MAP sensor, and I will check again I did not see an oring for the MAP, it was never taken off, could Honda forgot to put in the o ring?
I have to go check again.
With you car was it an original MAP sensor?
How about CELs?
It is possible the factory forgot to put it in, mistakes happen.
Recently, there is a recall for Chevy Sonic for missing brake pads, so if that can happen so can a little o ring.
The honda replacement is like $2.73 retail which is crazy.
Anyone know the size of the o ring? so I can match it at the hardware store? Like mm????
Anyone have calipers?
Quick question when removing the MAP sensor will the o ring still be on the nipple of the sensor or will it stay in the hole?
Does the D16y8 o ring look like this, if so it will not get stuck to the nipple I guess?
im not getting any cel, i only have an idle prob (too low when warm and idle screw doesent work, idle wont go up) in my car and all the pieces related to the idle are in good working conditions, so i check the service manual and it said that the map sensor and the idle screw use an o-Ring and my car dont have it
Yes, it have an original sensor
You mean what is the MAP sensor reading?
http://www.fastfieros.com/tech/map_s..._they_work.htm
your car has the o-ring, look at the black circle around the map sensor hole in the throttle body, that is the o-ring
Why are you making this harder than it is? Replace the damn O-ring. What do you need to see another picture of another car for?
yeah!!, i have cleaned thousand of times hehehe, but i dont understant why the idle problems (rough idle, and vibrations) only apear when the car is warm to operating temperature, today i was cheking the TW sensor and all is fine
all still the same
