Drag dr-44 fitment
Old Jan 3, 2012 | 02:53 PM
jdmchickx's Avatar
Default Drag dr-44 fitment
15x8.25 +25 offset on an ek hatch lowered on d2 coilovers. 195-45-15 tires
anyone have any pics of these wheels on their car??
Old Jan 3, 2012 | 06:32 PM
toyomatt84's Avatar
Sanji
Default Re: Drag dr-44 fitment
There's quite a few problems with what you're requesting.
1. Without modifying the car's fenders and quarter panels to increase wheel and tire clearance, you won't be able to fit those wheels without an unsafe amount of negative camber.
2. The widest wheel a 195/45/15 is rated for, is a 7.5" wide wheel.
3. The 195/45/15 tire size is 6.65% undersized for your car. A safe range is less than 3% different than factory.
Old Jan 3, 2012 | 07:55 PM
Rockets's Avatar
195 tires on 15x8 the lip of the rims will stick out a bit from the tires.
Old Jan 3, 2012 | 07:59 PM
rhdtreehugger's Avatar
have u tried google if u just want pics...but i see wat your going for that poked out look
Old Jan 5, 2012 | 02:15 PM
jdmchickx's Avatar
I'm not worried about the tire size, the stretch is just what I want. I'm just wondering about the offset and tire width. I wanna know if I can fit that size on my car without having to run too much camber and obviously without sitting on fenders. I'm rollling and shaving my fenders.
Old Jan 5, 2012 | 03:12 PM
toyomatt84's Avatar
Sanji
You shouldn't have too many problems clearing the fenders, but sadly...
From the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
This type of question is better suited for the Appearance forums, if anywhere.
Drewsgotshoes
Feb 18, 2017 08:30 PM
pxlds
Aug 25, 2014 09:24 PM
em2-matt
Sep 27, 2011 12:22 PM
D C 2
May 17, 2009 01:34 PM
jdmjunkieXL
Oct 26, 2006 11:43 AM
