del sol question for friends 95 sol, help!
Old Oct 8, 2002 | 10:32 AM
ImprtTuner88's Avatar
Default del sol question for friends 95 sol, help!
Here is his question.
I just wanted to get everyones opinion on doing a type r wheel conversion to a 95 sol. I have the access to the complete suspension and the 4 lug type r wheels. The tires are decent. They came off of a 95 jdm type r. I just got my del sol back on the road after the b16a hybrid swap the wheel bearing went bad and the tires need to be replaced. I need some opinion because i will be set to only being able to use accord and prelude wheels on the car after the swap. i have someone that i can unload my fornt suspension to do a conversion on a type r integra, for drag racing purposes.
Thanks for any info guys
Old Oct 8, 2002 | 10:49 AM
Default Re: del sol question for friends 95 sol, help! (ImprtTuner88)
anyone? Pro's............Con's
[Modified by ImprtTuner88, 2:49 PM 10/8/2002]
Old Oct 8, 2002 | 10:53 AM
stevecockrill's Avatar
......4 lug type r wheels.......
Didn't know ITRs came in the 4 lug variety........
Steve
Old Oct 8, 2002 | 10:59 AM
tz-devil77's Avatar
Default Re: del sol question for friends 95 sol, help! (stevecockrill)
95 is the very first year in Japan for the type r it did come with a four lug wheel set up. Just wanted to see what everyone thought about doing hte conversion.
Old Oct 8, 2002 | 11:00 AM
sure did, in 95 they did, have a clip in raleigh, nc.....................it is for sale actually. Contact jeremy gast at Japan Direct for more info. email: jeremy@engineman.com
Old Oct 8, 2002 | 11:32 AM
ttt
Old Oct 8, 2002 | 12:15 PM
SoloSol's Avatar
If it has the same 5mm wider track and the big brakes, get it.
Old Oct 8, 2002 | 12:35 PM
Default Re: del sol question for friends 95 sol, help! (SoloSol)
For sure. That'd clinch it for me. Unless you can't get wheels to fit.....is the bolt pattern 4 x 100 or 4 x 114.5??
Steve
Old Oct 8, 2002 | 05:20 PM
.honda.'s Avatar
juss keep it four lug..save yourself the hassel
Old Oct 8, 2002 | 05:54 PM
4X114.5
Old Oct 8, 2002 | 06:31 PM
Well, not speaking with the massive voice of wisdom here, but that's the same bolt pattern as Preludes and Accords, right? So finding wheels won't be a problem. The only issue would be as to whether you could get the correct offset wheel.
Alternatively, how about just replacing the 4 lug hubs with 5 lug? Can that be done as a direct part swap in this instance?
Steve
Old Oct 9, 2002 | 10:50 AM
here is a pic of the front clip in case anybody had never seen a ITR with 4 lug 4 X 114.5.
Old Oct 9, 2002 | 10:58 AM
Black_eh2's Avatar
New User
you got this from larry ? importautosalvage?
Old Oct 9, 2002 | 11:01 AM
Default Re: del sol question for friends 95 sol, help! (SleeperEG6)
nope, Japan Direct............ Jeremy Gast, Raleigh, NC
UsMcBaldie
Feb 26, 2010 11:11 AM
jrthecow311
Jun 21, 2003 03:39 PM
