Power steering delete
could not find an answer for this via search
I would like to remove the power steering pump - however, there appears to be two lines that run from the power steering reservoir to the very top of the differential. Does anyone know what it is? I'm guessing some type of speed assist powers steering device...any help is greatly appreciated. Thanks
thats the speed sensor. when removing the power steering simply loop the lines. to keep some fluid in and keep dirt out of the speed sensor. it will work fine with the lines looped
clewis152
Aug 7, 2012 05:01 PM
