MD FS: Part out, ChaseBays CM2, SSR, S2000 start button, S300 p28, Regamasters, more
I'm parting out my car and have a bunch of stuff to sell
1. Chase Bays CM2 Bseries harness, It was made for an OBD1 Bseries vtec motor, I will include the firewall plate/hardware and the chase bays supplied jumper harness to make it work on an EF and instructions..... $550 OBO SOLD
2. P28 ecu with Hondata S300 installed, I purchased it from Phearable a few months back, I will include the Hondata license plate frame, box, cd and datalogging cable..... $500 OBO SOLDDDD
3. SSR Street Sweeper Header coated by JetHot, I paid around $1250 shipped for it with the option of stainless and a v-band flange, I ordered it straight from Danny Tran himself then shipped it to JetHot and paid $200 for the ceramic coating, it has a 2.5'' outlet and is in awesome shape minus a very minimal scrape on the bottom. This is a beautiful header and is very good quality...... $800 OBO
before coating
after coating
on the motor
4. S2000 start button kit, I bought the kit from checkerdsports.com and made it almost completely plug and play, it just needs to be hooked into the fusebox accessory spots, 1 to accessory power 1 to constant power then ground 1 and hook the other to the starter signal wire, gives it the race car feel lol....... $75 shipped SOLD
5. Desmond Regamaster Evo's with dunlop direzza z1 star specs on them. The tires are practically new and have maybe 5,000 miles on them, no track events or burnouts on them. They come with all brand new stickers, including lip, spoke and barrel stickers with specs printed on them. the wheels are in decent shape but could def use a good cleaning and recoating. I'd like to get $1100 OBO
wheels when i first got them
6. All In Fab tucked radiator, awesome piece, awesome quality work and design, i paid around $450 all together for the radiator, filler neck modification, and fan/shroud. The coolant neck is for an b16/Itr head but can be modified if you have the skills, ill include the samco hoses for a little extra if wanted..... $300 OBO SOLDDDDD
7. Suspension Techniques EF drop forks, These are extremely hard to find these days. Perfect for lowering your car and keeping much needed shock travel...... $250 obo
8. Rc 370cc injectors, used but in good condition, never any problems out of them... $180 shipped
9. Itr throttle body bored by Maxbore, used for 10,000 miles, comes with omni tps installed.... $180 shipped OBO SOLD
10. Jdm Itr intake manifold, slightly ported, tb opening port match to throttle body, includes iacv and iat and hondata gasket.... $175 shipped OBO. (on motor in the above pictures)
before coating
after coating
on the motor
Its not completely ply and play, all you have to do is plug the red and yellow wires into the accessory plus on the fuse box, ground the black wire, and you'll either have to cut the starer signal wire and solder the orange wire to it, or just splice it to the starter signal which will allow you to still use the key to start also (best idea imo)
