Suspension & Brakes Theory, alignment, spring rates....
RSR springs help
Old Jan 2, 2012 | 04:15 PM
Moses_JDM's Avatar
Default RSR springs help
I currently have RSR spings and stock replacement shocks for my EG8, I get allot of body roll. What other shocks could I use with the springs for better cornering? Or should I just get a set of coilovers?
Old Jan 2, 2012 | 04:23 PM
grumblemarc's Avatar
The Grumpiest
Default Re: RSR springs help
Do you even know what spring rates those RSRs even are? You can get the best shocks there are but with crappy rates it won't make any difference.
Old Jan 2, 2012 | 04:51 PM
Moses_JDM's Avatar
The springs are 245f/175r. Very soft
Old Jan 2, 2012 | 05:16 PM
The Grumpiest
What's your budget? Progress makes an excellent budget coilover. Many people are running these, including me, and I have yet to hear a complaint. I'd get the 350/250 or 350/350 rates.
Old Jan 2, 2012 | 05:51 PM
Moses_JDM's Avatar
was thinking about the ground control coilover sleeves with my stock tokico gas shocks.
Old Jan 2, 2012 | 06:07 PM
The Grumpiest
Tokico blues? Those are stock replacements. If you want to blow those out go ahead.
Old Jan 2, 2012 | 06:09 PM
Moses_JDM's Avatar
whats your recommendation
Old Jan 2, 2012 | 06:13 PM
The Grumpiest
I already gave you my recommendation. If you're just looking to improve your stance a bit and greatly increase ride quality then get the Progress CS2s. If you're just wanting to slam the car get what all the fanboys get and but Function & Form.
it might be more helpful if you gave us a budget that you are working with.
Old Jan 2, 2012 | 06:15 PM
Moses_JDM's Avatar
I want to get the car to handle better. I will check out the progress and the tein
This is the specs for the current springs:
Model - Civic Year - 1992 - 2000 Model Notes - ALL Estimated Front Drop - 40mm(1.6in) Estimated Rear Drop - 25mm(1.0in) Front Spring Rate - 4.33kg(242lbs) Rear Spring Rate - 3.00kg(168lbs)
Old Jan 2, 2012 | 06:48 PM
The Grumpiest
Tein basics are crap too.
Old Jan 3, 2012 | 04:02 AM
Moses_JDM's Avatar
Ok! I will look into the one you suggested.
.xcalibur.
Suspension & Brakes
Aug 19, 2007 03:49 PM
Kill_Phil
Suspension & Brakes
Jun 6, 2005 04:08 PM
darkvibe
Aug 30, 2003 07:44 AM
stoopid215
Sep 19, 2002 08:30 AM
Duck Sauce
Dec 21, 2001 07:58 AM
