Leak Down Test...how to?
Old Jan 2, 2012 | 04:15 PM
asondemitri's Avatar
Default Leak Down Test...how to?
So i want to check to see if my valves were damaged when i broke my timing belt. I keep hearing "do a leakdown" test...but not sure how to perform it. I assume i pressurize each cyclinder with a specific amount of air and see if it bleeds down in a time given. So, does each cyclinder need to be at TDC? how much pressure? how long? and do i need to fab a tool or does harbor freight sell it?
Thanks in advance...
Old Jan 2, 2012 | 04:52 PM
JamesB1985's Avatar
Default Re: Leak Down Test...how to?
I think harbor freight would have a leak down tester. You need compressed air to hook up to the particular cylinder your testing, you will hook the air up to the cylinder through the spark plug hole at say 100 psi. The you will listen for this compressed air coming from various area's of the car...
Example - Throttle body = broken intake valve
Exhaust pipe = broken exhaust valve
Bubbles coming up under radiator cap = head gasket leak
Open oil cap, hear air? = broken piston rings/ hole in piston
You get the idea... The tester will show the amount of leakage you are getting from each cylinder. Below 20% is OK. It should really be below 10%, depending on wear on engine, how many miles etc.
Old Jan 2, 2012 | 05:14 PM
exb18c1's Avatar
Or do a compression test.
trecool44
Oct 6, 2008 05:42 PM
nemesis25
Feb 22, 2008 06:46 PM
divingcorners
May 29, 2006 03:03 PM
B2FiNiTY
Jul 21, 2003 01:02 PM
