Jdm Itr cluster 01 gsr
Old Jan 2, 2012 | 03:59 PM
GdmLaz's Avatar
Default Jdm Itr cluster 01 gsr
well i recently got a 01 gsr which came with a jdm itr cluster and the temp gauge and is not working is all the way hot..... I did some research and read that you could just swap out the green part of ur usdm gsr cluster into the jdm itr one..... My question is i obiously don't have my stock cluster since i bought the car with this one..... Can i just buy an ls cluster and swap out the green piece to the jdm itr.... or does it have to be an 01 gsr cluster that i need to get the green piece off....... Thanks :D
Old Jan 3, 2012 | 02:34 AM
GdmLaz's Avatar
Default Re: Jdm Itr cluster 01 gsr
any ideas ?
Old Jan 3, 2012 | 11:37 AM
mouseitr's Avatar
I would have to say that it shouldn't matter all though I've never had this problem. But Ive had a Ls gsr and type r and have swapped my 01 type r cluster through all three and have never had a problem with wiring, but you shouldn't have a problem
Old Jan 3, 2012 | 11:58 AM
mark@silbernage's Avatar
Re: "and the temp gauge and is not working is all the way hot" == pegged at "hot"?
What happens if you unplug the temp sending unit? Perhaps the sensor is out?
Old Jan 3, 2012 | 07:46 PM
1998GsRIntegra's Avatar
I've never heard of the temp gauge not working, its usually the fuel gauge. As far as I know the green film is just an obd1 obd2 thing. When I installed a '96 spec jdm itr cluster in my '98 gsr I had to swap the green film because the fuel gauge was not working.
hype_R
Apr 8, 2008 05:35 PM
01DC-2
Apr 1, 2004 09:43 AM
siis2fast
Apr 17, 2003 05:32 AM
P1mpSlap
Nov 30, 2002 11:57 PM
