Compression ratio
right now I have a b16 with wiseco 9.5:1 pistons in it. I'm running it all motor for awhile until I can save up for a turbo kit. It's pretty slow right now with the low compression but if I was to deck the head and put a 2 layer head gasket on there what would it bring my compression up to? An would I be able to tell a difference?
Leave it be. Shouldn't have went that low compression anyway.. With the advancements in tuning and parts, people are getting smarter and running high compression turbo setups. This means Less boost = more power, the turbo becomes more efficient at lower boost levels because of the higher compression.
11:1 @ 12 psi will make more power then a 9:5 setup @ the same boost level.
TehMoonRulz
May 16, 2005 01:15 PM
RooskiGSR
Feb 28, 2005 04:23 PM
s0liDyNe
Jul 19, 2003 10:24 PM
