2002 Accord won't start - battery charged
2002 Accord SE 4 cyl. - 202K miles
Got in to start it last night....all instrument lights came on, interior light, headlights work - won't turn over.
I can hear 2 clicks underneath the steering wheel when I turn key to Start position.
I got under hood and had a friend turn key for me - I could hear the starter solenoid click once when key is turned to Start position.
I don't think it's related, but I just changed the oxygen sensors this weekend. Once was bad - replaced them both while I was at it.
I tried tapping the starter with a small hammer, but that didn't help. Cleaned battery posts and cables. Attempted jump start from another vehicle. Still nothing.
Any suggestions?
Much appreciated.
Any suggestions?
Much appreciated.
YEAH - there is a green key light flashing. I tried starting with the Valet key, but that didn't work either.
I have a volt meter, but haven't checked the voltage to the small wire. Can do, though.
I just searched for the Green Key Light on the forum, but still reading through the search. What does that mean? Should I try starting with my wife's key?
Okay - green light goes off just as it should.
Volt meter on the small wire on starter is showing about 9 volts when key is in Start position. And I can hear the solenoid click.
I put a load tester on the battery. It shows 12volts but goes to Weak (10 volts) when under a load. Don't think this should affect it, though as I had it connected to a good battery last night (jumping it) trying to rule that out.
Think it's the starter?
Flexxon
Jan 4, 2017 11:13 AM
Just_me_chris
Jan 8, 2009 03:32 PM
