Shuddering, low power
Old Jan 2, 2012 | 04:41 AM
frasheman33's Avatar
Default Shuddering, low power
hey all, I have a 95 integra ls and am having a bizzarre problem. once the car is warmed up if you give the car throttle to accelerate the car shudders violently. when this happens the car has a severe lack of power and when at a stop the idle fluctuates. when the problem initially started it was only an issue between 2500-3500 rpm, and once you got higher into the revs it went away. now however, once the car begins shuddering the problem persists all through the rev band. i initially thought that it may be a bad o2 sensor so i changed that to no luck.
flashing out the code gave me i believe a 41 (o2 heater sensor) but it could have been a code 5, which would be a bad map sensor.(when reading the code i am aware that a long flash =10 short flash=1, although the first 4 flashes did not seem very long the last flash was noticeably shorter), the 41 would make sense as i the car flashed a code while i was changing the o2 sensor. the car never threw a CEL under normal driving however.
i am trying to avoid throwing hundreds of dollars in sensors at the car so any insight you guys have would be awesome!
Old Jan 2, 2012 | 06:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: Shuddering, low power
How's the fuel pressure?
When was the last time the fuel filter was changed?
Have you checked/tested the TPS?
Does this, [shuddering] happen once engine is warmed up or even when cold? 94
Old Jan 2, 2012 | 07:58 AM
b20bFourDoorCivicLX's Avatar
valve adjustment
Old Jan 2, 2012 | 11:17 AM
shuddering happens only when the engine is warm, fuel filter was changed about 2 months ago.
have not checked tps or fuel pressure yet, dont have a fuel pressure tester but may be able to check the tps tonight...
Dubs13
Sep 26, 2009 09:46 PM
v8killaz
Jul 13, 2009 09:55 AM
twentyhurtz
May 19, 2009 03:33 PM
PWRDbyHseries
Feb 22, 2006 04:53 PM
Ninety5Ex
Mar 3, 2005 10:20 AM
