2012 New Year Sale!!!DEALS
Whats up i got some things to get rid of New year..New things....Im located PA,15478 PAYPAL IS READY IF NEEDED
1.ACT PRO-LITE B-SERIES FLYWHEEL....$100.00 Shipped
2.B18C1 USDM CRANK ..Great Shape...Came out of my b18c1that cracked ring lands/Cracked Sleeve So parting out $160.00 Shipped
Pics If Needed
3.Garrett T4 Twin Scroll....A/R .70 Intake side....1.32 Exhaust twin scroll...3"V Band Flange...Shaft is pretty Tight...I would probley put some new sealS in it.(Has lil Chipp where u bolt intake housing on PICTUED..$325.00 Shipped/PAYPAL'D
(One with BLACK Intake Housing
4.94 Integra LS 14" Hubcaps....Mint condition...$30.00+Shipping
5.B18C1 Used Knock Sensor.Round Plugou..Works perfect...$30.00 Shipped
6.ALOT OF MOUNTS ANYONE U SEE IF U NEED MAKE OFFER OR ASK
7.94 INTEGRA COUPE Rear whiper motor....$30.00 shipped
8.B18C 1&5 MAIN CAPS & #2/#3/#4 Main Girdle....$100.00 shipped/Paypal
9.B18C1 USDM OIL Cooler Set Up...Thromostate Tube/Hose's/Oil SandWich Cooler to Block/With Bolt for Sandwich/Oil Filter...$100.00 Shipped
B18C JDM OIL COOLER SET UP...FULL SET UP FROM OIL SANDWICH TO THRMOSTATE TUBE/HOUSING/Hose's....$old to 1984EGhatch
10.Autometer Phantom AIR/FUEL Gauge...$25.00 shipped//////Off brand vaccumm Gauge good to read if u want vac leak $13.00 shipped
11. ECUS
OBD0 PR4 B18A1 (MT) 90-91 $50.00 Shipped / OBD1 P07 D16Y5 Damaged..Burnt Resistor...$30.00 Shipped / OBD1 P05 D15B8 (MT) $65.00 Shipped / P2P D16Y8 (MT) $65.00 Shipped / OBD2 P2E D16Y7 (MT) $50.00 Shipped / OBD2 P2E D16Y7 (AT) $35.00 Shipped
12.92-95 Civic EX Coupe...Rare Rear Speaker Pods&Covers...One has lil crack...$45.00 shipped
13.EBAY TURBO...Needs a New Exhaust shaft/wheel...Everything eles is good...The exhaust wheel just twisted off Shaft...$45.00 shipped
14.EG CIVIC GRAY DASH COVER $ 25.00 SHIPPED
15.RANDOM SENSORS OFFER IF NEED
16.SPEC STAGE 3 B-SERIES HYDRO Pressure Plate...Ran on turbo LS 17 Psi for 7,500 Miles Held perfect...$60.00 shipped
17.ACT STAGE 2 PRESSURE PLATE HAS 18K Miles But stil can be used...$30.00 shipped
18.SRP 10:5:1 81.5 mm B-SERIES Pistons/Rings...Only 1,500 Miles...Still Have In Box With Spec Sheet...$335.00 Shipped !
on left next to srp 9:2:1 $375.00 Shipped.... .20 over 2 dyno runs/3 track pass's (Theres 4 I just couldnt fit the 4th in close up pic
19.91 INTEGRA LS 5 Speed Gauge Cluster $40.00 Shipped
20.IM PARTING OUT A 90-91 INTEGRA...NO Motor
21.98 INtegra GSR Black Passenger Side Air Bag...Great Condition....$47.50 Shipped
22.F22 Non Vtec Valve Pan Cover...(Sand Blasted)So its Bare Aluminum Ready For Paint/Powder Coat...$35.00 Shipped
23.nEW kNOCK sENSOR...Sqaure Style Plug...Can Be Used on B,D,F,H Motors $45.00 Shipped
24.91 Integra B18A1 pOWER Steering Pump..$30.00 shipped
25.(5) CTR PCT B16B Pistons....STD Size....3 Are From One set&2 from other....One has Dentonation Marks...But u have 4 to Run...Take all 5 for $80.00 shipped
27.92-95 Civic SI Black Steering Wheel/Steering Colum/With Key &Harness...etc $145.00 Shipped
28.D15B8 FULL COMPLETE Top End....I have Complete D15B8 Non Vtec 8 Valve Head...Obd1 Complete Intake Manifold/92 civic vx Intake Tube/Box....D15b8 obd1 Distributor....Also Have 5 Speed Ecu for it....P05 I think it is....$300.00 Shipped For whole set up(Great To throw On a None Vtec Block and get 40+ MPG
29.F23A1 I think its A1 But Full Complete F23 ULEV Vtec Head..Has Valve Cover/Complete valve Train...Has Distributor With Head But needs a Distributor Cap and Rotor Button..I dont have the Parts for its Not like B-series dizzys....$210.00 Shipped For head and Dis
30.DOHC ZC Half Shaft $55.00 Shipped ...And DOHC ZC Driver&Passenger side Axles...The Inner Hubs were Tooken off...Boots
are still good Just Need clamped on...$75.00 Shipped....Or All 3 for $115.00 Shippped
31.GSR Hydro DIFF...Pin Droped in it...But Ring Gear is Still Perfect Condition....$60.00 Shipped....Also Have GSR Hydro Counter Shaft(The drive Gears (Not with all scyros The Other....All the Gears are Mint...$145.00 Shipped
32.Parting Out D16Y8 Block....No Oil Pan ...And Spun Rod Bearings...
33.88-91 Civic D-SERIES Rear Tranny Bracket...$17.50 shipped
34.91 Integra Cable 5 speed Pedal Set....$45.00 shipped &I can include the Cable Tranny Cable for extra $15.00
35.94 Integra Mint Gauge Cluster Bazel...$13.00 Shipped
36.96 Integra GS Rear Sway Bar...$65.00 +Shipping
37.92-95 Civic Cruise Control Units....x3.....$25.00 Shipped
38.92-95 Civic SI Full Power Steering Set Up...For D-SERIES Vtec...Includes...Power Steering Pump/Bracket/Resovolor/Main Line From Pump To Rack/P/S Loop Cooler In Front&Hard Lines From Rack to Pump....$115.00 Shipped/Paypald...
(ALSO Have 3 or 4 more P/S PUMPS /Wit Brackets $40.00 Shipped Each
39.DSM 1G Fuel Rail/Fuel Pressure Rewgulator OEM...$40.00 sHIPPED
40.86-92 Mazda RX-7 FLUIDYNE Aluminum Racing Radiator...Has Bent Fins But Doesnts Leak...thIS Model Retails For $Just Shy of $500 On Ebay....$115.00 Shippped
41.B-SERIES Lower Timing Covers...I have Mostly OBD1S...$17.50 Shipped Each&Have 1 or 2 OBD2 GSR &B18B Lower Timing Covers With Room For Crank Sensor....$30.00 Shipped
42.96-98 Civic Front Driver Side Head Light...Neeeds Cleard Up...$45.00 Shipped
43.
44.Coupe Sets of B18a1 Rods and Pistons...$45.00 Shipped Each set...
45.B18A/B Eagle H-Beam Rods...Only 2...Dont Have Rod Bolts...But can Be Used if u Have 2 or 3 jUST Put set together....$50.00 Shipped For Both &Ill throw in the 3rd One thats Bad
46.Jackson Racing Fuel Pressure Regulator....No Bracket For Fuel Rail...$35.00 Shippped]
47.D16Z6 OEM FUEL RAIL/WITH FUEL PRESSURE REGULATOR $15.00 Shipped
48.B18a1 Bare Intake Manifold.. $33.00 shippped
48.96-98 Civic DX Tan Glove box...great shape $30.00 Shipped
49.88-91 Civic Rear View Mirror..$20.00 Shipped///88-91 Civic Poop Brown Glove Box...$17.00 shipped
50.92-95 Civic OEM Front Upper Control Arms...Ball Joints Are Decent...I would Regrease them...$45.00 Shipped for Pair...Also have bushings that bridge across to go up into the Bay to bolt
51.92-95 Civic SI Black...Mint Dash...Has Complete Under Dash Harness....No CLuster/Cluster Cover....I think theres a Glove Box...$100.00 picked up
52.D16Y8 OBD2 D-SERIES ALTINATOR..64K Miles...$45.00 shipped
53.D16z6 OBD1 ALTINATOR...PERFECT WORKING CONDITION JUST DOESNT HAVE A PULLEY...$35.00 SHIPPED
54.92-95 Civic Ex Coupe...Both Side Outer Tail Lights $30.00 Shipped for Both
55.B16A OBD0 JDM Throttle Body...No Tps &Map Sensor Goes on Engine Bay or u can run Vaccum Line from TB To a Map....This is Offical Its got Jap Writing on Bottom its 61mm....$60.00 Shippped
56.94 Integra Coupe 3rd Brake Light $15.00 shipped..
57.95 Civic SI Front Sway Bar with Endlinks....$20.00 Picked up
58.94 Acura Integra LS 14" hUBCAPS...2 Painted Black....2 OEM sILVER...was kinda Faded so I Painted And idnt Finish These Are Really Mint....$42.50 Shipped
59.95 Civic SI Stock Front Struts///Springs....Struts Have Under 60k Miles...Driver&Passenger...Can Include Forks If Needed...$50.00 For Set or 55.00 with forks....+Shipping
60.
I got tons of OTHER PARTS JUST ASK
Pics If Needed
11. ECUS
43.
60.
I know its the New Year And After Holidays And Moneys Tight...But come on Help a Bro out....Ill cut you deals if u buy 2 or more Items And may give you a deal if u just need 1....I also got DA INTEGRA 5 Speed parting out
Thanks EGHATCH...Items will be shipped out Tommorrow....Bump....I Have some Parts Off a 90 Integra LS....Whole front clip/15/16 master/brake booster....Front/REAR sway bar....5 sPEED Gauge cluster 200k club ....and got alot more offer
***EDIT*** Worked things out with seller, finally got my stuff and everything went smooth, so buy with confidence...
NIKE SB'd
Southwest (Sales)
Apr 15, 2007 10:43 PM
