95 Civic - replacing my cylinder head
Old Jan 2, 2012 | 02:26 AM
travbrack's Avatar
Default 95 Civic - replacing my cylinder head
Hey guys. Blew my head gasket and so I'm tearing the engine apart. Definitely the most involved car repair I've ever done. Here's some pics:
To get this thing off, I just need to remove the crank pulley and the timing belt. Hopefully I can get this thing wrapped up in a few more days! I don't have air tools so I'm planning on trying the 5th gear big *** breaker bar method to get the pulley off. Just thought I'd share. Hope you like the pics!
Old Jan 2, 2012 | 05:30 AM
Markley02's Avatar
Default Re: 95 Civic - replacing my cylinder head
Can't you just loosen to tensioner and slide the timing belt off the cam gear? Maybe even do one better, loosen it, zip tie the belt to the cam gear, and take the cam gear off of the cam shaft. I haven't done this on any d-series, but I can't see where it would be an issue
Old Jan 2, 2012 | 08:54 AM
Former User's Avatar
http://www.amazon.com/Powerbuilt-648...5526792&sr=8-1
Old Jan 2, 2012 | 08:59 AM
Mr. EG's Avatar
Looks like Cyl. #3 has a small amount of oil in the port. Make sure to inspect valves and the head for issues.
Old Jan 2, 2012 | 09:01 AM
Is that oil or carbon from unburnt fuel?
Old Jan 2, 2012 | 09:09 AM
Mr. EG's Avatar
It may be raw fuel (depending on how long it has been sitting there). It looks more like oil residue to me, OP can you confirm?
Old Jan 2, 2012 | 11:56 AM
travbrack's Avatar
Yeah it's oil.
Old Jan 2, 2012 | 12:01 PM
98civdx's Avatar
Master Detailer
You don't need to remove the crank pulley, unless you want to replace the belt.
Which I would.
Did you mark the distributor ears before you remove it? It would still be a good idea to check/set the ignition timing.
DumpdEJ6
Sep 12, 2010 08:05 AM
Swansen
15
Apr 1, 2009 02:39 PM
jtchinoy
Jun 24, 2006 11:02 PM
corymedlin
Dec 29, 2003 10:57 AM
