H22 head swap oil block off???
I did all the research and know what im getting into. But i just need a pic of witch drain ports to block off to put a H22 head on a F22b2 94 block. The thread i seen the pics dont work on it anymore
Block the last two where the timing side is you should know what they look like but it's still might leak a little on the f22 blocks the head gasket of the f22's barely cover the other oil drain ports on the vtec solenoid side of the head it leaked on mine. Just place the head gasket on the head and you will know which ones to cover.
robert95348
Nov 26, 2006 04:05 PM
