92 Civic cx/b16sir2 swap - Need help with Ecu to harness pinning
Ok so heres the story. Owner before me swapped a b16sir2 in a cx eg hatch 1992. Used the stock cx harness and pinned the ecu and ran the wires out to the sensors and the vtec solenoid. Well the past few days i ripped the motor out so i can put a fresh b16 in
and tranny. I have an obd1 vtec harness for a b series. I hooked it all up to the engine, havent put it in yet but im working on it. So anyway sense i have everything all wired up STOCK id like to repin the wires from the ecu to the original connectors ... Im not sure what goes where and whats what and blah blah. sooooooo idk where to start and im going to have some problems if i dont pin these. IM NOT CUTTING A PERFECT HARNESS
Anyway pictures would just make my day
thanks guys. Let me know if i should put up a swap thread.
i could really use some information/ help on this. i just got the motor in almost ready to start but i need to pin those wires, i have no idea how to do it and where the wires are going.
Is this what you are looking for?
http://www.phearable.net/tech/wiring/wiring.92-95.jpg
What specific ECU and wire harness do you have?
ok i got my engine in and running. Distributor timing is off, but i will fix that tomorrow. Few wiring questions sense my check engine light is on
didnt use to be. Anyway there is a plug on the intake piping, i believe its the air temp sensor or an o2 sensor or something. No idea didnt have one on my integra. But i guess the p28 uses one. It could be the same thing that should be on my intake manifold. Some sort of plug next to the fuel rail? but i dont have one of those . I have a few wires hanging. I need to pin the vtec wires to the interior harness so i can run it through my plugs on my wire harness i have. The other 2 or 3 idk what they are... ones in the back, its not the knock sensor... The other is up by the throttle body but does not fit in the thing on the intake piping. And the other one is near the passenger side . I never notice an o2 sensor for the exhaust manifold. The harness is off a obd1 gsr and my ecu is chipped to not use a o2 sensor. Id like to get it tuned to use the o2 tho. Sorry newbie at wires
thanks ignore my bad grammar.
