em1 roll cage
Old Jan 1, 2012 | 04:42 PM
Crazy_SI_T's Avatar
Default em1 roll cage
With the season starting back up its time to equip the car with better safety specs to further my goal of tens. Can i get some suggestions on a good brand. Also if you have one installed in your si please share
Old Jan 1, 2012 | 04:45 PM
98civdx's Avatar
Master Detailer
Default Re: em1 roll cage
Custom!!
Make the trip over here, and have ricky at SF make you one. or, see if can make it, you install it.
Old Jan 1, 2012 | 04:48 PM
GSaura's Avatar
There's a rollcage FAQ in the RR/AX section. It's best to look in the rulebook for whatever series you're running to determine if an off the shelf cage like the autopower cage will work. You may have to get one fabbed by someone local if the autopower cage isn't stout enough. Im not familiar with any brands other than autopower. I got an autopower roll-bar through safe-drives.com at a pretty good price. The roll-bar bolted right in like it should have. Very satisfied with the fitment, fit, and finish.
Old Jan 1, 2012 | 06:14 PM
Crazy_SI_T's Avatar
The car did an 11.4 with alot more in it but i need a cage. Thanks for thr advice on were this section is.
runsfromdacops
Dec 15, 2009 01:39 PM
Mugencrxsir1
14
Sep 3, 2008 04:24 PM
motore
Sep 30, 2005 10:36 AM
black3door
Mar 11, 2004 01:55 PM
Gmedalion
Mar 6, 2002 01:17 PM
