98 civic ex trailing arm bushing
I might have made a mistake on ebay and purchased rear trailing arm bushings for a 1991 civic crx. Will they still fit on my 1998 civic ex?
I checked on kragen oreilley and the part number is the same. The ebay ones should fit right?
If they do fit, should I tell the seller to proceed with my order and send?
Thanks!!
ebay: http://cgi.ebay.com/ws/eBayISAPI.dll...ht_2582wt_1023
car parts discount: http://www.carpartsdiscount.com/auto...ml?3593=268648
Thanks!!
Did you check the compatibility chart they provide you in that auction? When you do it will tell you "This part is not compatible with 1998 Honda Civic". In the second link it plainly says
"Vehicle Model Applications Parts: Suspension Trailing Arm Bushing Honda CRX 1991" However everytime I look on Ebay it says the trailing arm bushings fit 88-00 Civics.
I cancelled everything. Hopefully, the ebay seller is accommodating, because according to a service bulletin from Feb 2002, that exact part being sold on ebay is considered a failed part.
theineffable
Honda Civic (2001 - 2005)
Oct 12, 2010 04:12 PM
Pompiuses
Oct 16, 2007 01:26 PM
