CRX transmission info
Old Jan 1, 2012 | 12:15 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default CRX transmission info
I need the 1991 CRX L3 transmission output spline count and shaft diameter info, attempting to plan out an intermediate shaft install from an AWD civic.
Cheers.
Old Jan 2, 2012 | 06:31 AM
jlicrx's Avatar
Default Re: CRX transmission info
L3 output shaft diameter = 26mm with 25 splines
AWD and JDM ZC L3 transmissions = 28mm with 27 splines
you cannot use the AWD intermediate shaft on any of the non-AWD transmissions - the shaft itself, when bolted to the block, sits about 1/2" too high and the shaft won't go into the differential - AWD intermediate shaft will only work with AWD transmission
AWD intermediate shaft bracket on left - JDM ZC bracket on right
Old Jan 2, 2012 | 08:34 AM
solid info! ZC transmission is the only option it seems...
Old Jan 2, 2012 | 09:20 AM
94EG8's Avatar
Seagull Management
I posted this in GDD but I figured I'd post it here too in case it helps someone else out in the future:
Originally Posted by 94EG8
Here's some info I gleaned from thezcr, it supposedly came from an engineer at Honda USA.
The half shaft for the ZC is the same as the one used on the '90-91 Civic Wagon 4WD 1600 (M/T). The part # is 44500-SH9-010.
The axle seals for the ZC trans are the same as the ones used on the '90-93 Acura Integra. The part #'s are 91205-PL3-B01 (40 X 56 X 8) and
91205-PC9-711 (40 X 62 X 8)
The Civic/CRX has 35mm axle seal diameters vs. the ZC 40mm.
attentionwhore
21
May 13, 2008 08:05 PM
civic_hatch
Aug 15, 2005 06:24 PM
