aftermarket header gasket?
I got some headersfor my single cam and it needs a gasket and i went to autozone and kragan and they told me that there gaskets cant handle the heat of my headers so where should i get my gasket
I dont know alot about engines and i just got my first car
What?
This is why I hate parts stores. ****ing idiots.
I have a felpro gasket, about a year old and it's fine. Dealer was closed,so it was my only choice. If you can get OEM fine, but as long as you don't get some cheap *** gasket you will be fine as well.
I've always reused the stock gasket with no problems or leaks, unless you have a 4-2-1 and need the gasket that goes between the 4-2 section. In that case you'll need to make one using the exhaust gasket material sheets by Mr Gasket.
There's only one header.
krysted9354
Dec 17, 2008 05:45 PM
