Cool (short) video of my G2 ITR hybrid (0-95mph)...
http://www.axion.net/staff/ivant/files/G2Guru_Tach.mpg
It's much better to watch in "full screen" mode. Sorry for the poor quality, it was taken in MPEG mode of my digital camera.
9200rpm shifts?
sounds nice!
btw, are the spin dials for the climate control on your car oem? i thought integra's had the sliders, which suck.
Tom
sounds nice!
Tom
Transmission:
GSR YS1 Cable Transmission (5-Speed), Quaife ATB LSD, Centerforce Dual Friction Clutch, 13lb. Lightened & Balanced Stock Flywheel, Tenzo R Short Shifter, Energy Suspension Shifter Stabilizer Bushing Set.
Engine Modifications:
Fully Balanced B18C1 Block w/ JDM B18C5 Internals (11:1 CR), USDM ITR Top End (Head, Intake Manifold, TB), Portflow Headwork w/ Bronze Valve Guides, Toda Dual Valve Springs, Crower Titanium Retainers, Toda Spec B Cams, Toda
Gen 2 Cam Gears (+8, -2), RC 270cc Injectors, BBK 255lph Fuel Pump, STR Competition Fuel Rail, B&M CommandFlo Fuel Pressure Modifier (45psi), Toda Program OBD-1 P28 ECU, Apexi V-AFC (VTEC x-over @ 6600rpm), MSD SCI-L Ignition (Rev Limit @ 9400rpm), MSD High Vibration Coil, MSD Pro Distributor Cap, STR Cam Seal, Greddy 1.3 Radiator Cap, Mugen Thermostat.
Intake Modifications:
RS Akimoto Funnel Ram II Intake, Custom Cold Air Extension.
Exhaust Modifications:
Toda 4-2-1 Header, OBX-R Resonated Test Pipe w/ custom 2.5" flange, Thermal R&D Classic SS Catback Exhaust.
Suspension / Handling Modifications:
Skunk2 Coilovers (lowered 2.5"), Koni Yellow Adjustable Shocks, Specialty Products Camber Kit (Front & Rear), OBX-R Front Upper Strut Bar (Polished), Suspension Techniques Front & Rear Sway Bars, Focuz Rear Lower Tie Bar.
Wheels/Tires:
17" Volk SE37Ks wrapped in 205/40ZR17 Kuhmo Supra 712s.
Brake Modifications:
Brembo Cross-Drilled Rotors, Goodridge SS Braided Brake Lines.
And yes, 9200rpm shifts. Thanks for the comments.
[Modified by dplatt, 12:04 PM 10/8/2002]
Wheels/Tires:
Thanks guys. It was sheer heartbreak when the ITR motor took a dump because of shoddy machine work, but I rebuilt it better than before and I'm loving it. I just ran it at the dyno the other day and pulled 204.5whp and 139.8lbs of torque. I will post the graph when I have time to scan it in.
I ran the car at the track the other day on my 17" Volks with Kuhmo tires and full interior, and I was able to hit a 14.2 @ 98.3mph. The car weighs close to 2950 with me in it. It's a heavy car, but I love the look/feel of my car. And I absolutely love my motor. 9400rpm sounds so sweet!!! On slicks I'm anticipating low 13s. We'll have to see next season. That is if I don't decide to throw some 84mm sleeves and 84mm 11.5:1 pistons in there
Thanks again for all of the compliments guys.
. Thanks again for all of the compliments guys.
Tom
The car sounds sweet, but you really need to learn to shift faster. Hearing/seeing those shifts, you can definitely shave off another half a second on your quarter mile.
Well, I suppose it weighs more because I have all of my extras. Including sound deadening material. But I took the sub box out. I weigh 180 so without me the car weight in right around 2770, which is about 100lbs. more than stock. Hmmm....
30 lbs. sound deadening material
20 lbs. Heavier "beefier" Sway bars
15 lbs. Strut bars
That's all I can think of really? Weird. But I weighed it after I ran at the track at the local scales. I know if I took some weight out it would be even faster, but I'm into "comfort" for daily driving. I love my "luxuries".
As far as the shifting goes....I was shifting slow. I'm well aware. Rebuilt the tranny not too long ago and trying to take it easy on the synchros. At the track my shifting is more like this....
http://www.neek.net/videos/MOV00207.MPG
[Modified by dplatt, 5:00 PM 10/8/2002]
15 lbs. Strut bars
good guess
