wiring an starting help needed
hi i have a 91 hatch its turning over but no spark, an no power from the fuel pump, swapped a d15b7 block with a y8 head on it, an its all wired up except i have a clip coming from my firewall on the right side its 6 pronged an has
top 3 prongs-yellow, blue/yellow, yellow/black
bottom 3 prongs-brown/blue, red/black, lightblue/yellow
an i then have a clip off my engine harness thats 8 pronged
top 2 prongs- red, blue
middle 4 prongs-white, yellow, black/yellow, blue
bottom 2 prongs blue/yellow, yellow/black
theres also 2 wires coming from near my 1st injector that are green/white, an red/yellow that are just open ended an sitting in the same area as these 2 clips i need the car running tonight so please help all help is wanted
the smaller rectangle plug is the resistor box, and those other wires near the first injector is a sensor plug. its a circular 2 pin connector. not exxactly sure what sensor it is but it goes on the right bottom side of the intake manifold. atleast thats were it is on my b18
The 2 wires by the injectors would be your intake air temp sensor. As for the other plug, we need some info:
what model car do u have? DX or SI?
What year did the engine harness come from? By the looks of it you are attempting to use an 88 Si engine harness on a 90-91, which will not work.
