Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
03' TL Type-S No Driver low-high beam or either fog
Old Dec 30, 2011 | 05:29 PM
ndccpf1's Avatar
Default 03' TL Type-S No Driver low-high beam or either fog
2003 Acura TL Type-S
Replaced driver side HID ballast/igniter last year
Now driver Low (HID) / High (9005) beams not working
With engine off, using flash-to-pass causes passenger low AND high to come on
With car running and passenger low (HID) on turning on FOG lights will cause FOGS to be on for a few seconds then go off and this will cause the high beams (9005s) to both come on DIM
Driver side HID bulb is good
Scratching my head..
Old Jan 4, 2012 | 10:04 PM
wilp99's Avatar
Default Re: 03' TL Type-S No Driver low-high beam or either fog
sounds like something is wrong with the fog light switch. have you messed with any switches?
Old Apr 25, 2012 | 06:26 AM
awthentik83's Avatar
did you ever find out a solution to this problem? my 2002 Acura TL headlight is doing the same thing and it started smoking when i changed the bulb. Also my LOWER fog lamps are not working as well. Inside the dashboard in the car, the high beam icon wont even light up with the high beams are on. Any help would be greatly appreciated.
Old Apr 25, 2012 | 08:47 AM
ndccpf1's Avatar
The car went to the local mechanic where he cleaned are reseated some harness wiress leading the headlights and to the fog lights. All has been good since.
Toxin715
Dec 29, 2016 04:55 AM
civic4life8045
Lighting
Jul 21, 2011 12:47 PM
kroze
Lighting
Apr 28, 2009 06:47 PM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
stock97
Jul 29, 2003 02:27 AM
