d16y7 Block with D16a6 Head? Comp Ratio?
Old Oct 8, 2002 | 08:48 AM
FredoTheChimp's Avatar
Default d16y7 Block with D16a6 Head? Comp Ratio?
My friend just swapped a b18c in his DX hatch, and seeing how I already picked up a y8 manifold and JG 310x cam. I was wondering how much of an increase in compression would i see by using my d16a6 head on a d16y7 block. My a6 block has real good numbers (forgot um), but I would rather use the d16y7 because of its lower miles.
Old Oct 8, 2002 | 08:57 AM
Mugen Dom's Avatar
Default Re: d16y7 Block with D16a6 Head? Comp Ratio? (CRX_SOHC)
it would lower it by 1 point so if its at 9:1 now id be at 8:1 larger combustion chamber
Old Oct 8, 2002 | 09:02 AM
Default Re: d16y7 Block with D16a6 Head? Comp Ratio? (JdMB16Ahatch)
oh ok. Thanks For the info.
Old Oct 8, 2002 | 09:39 AM
Stupid Ass's Avatar
Perfect for a Turbo... man, that motor would scream!
Old Oct 8, 2002 | 09:56 AM
88civic's Avatar
i have heard of guys (dont know if its true) using the a6 block with the y7 head...would this work???? how is it done??? you just plug an oil squirter and use a stock head gasket.... nothing else????
Old Oct 8, 2002 | 10:03 AM
Mugen Dom's Avatar
Default Re: d16y7 Block with D16a6 Head? Comp Ratio? (88civic)
<<<<has a d15b1 block with a y7 head same head as a z6 with no vtec no modifcations needed it gives higher compression #s with the older d series motor i like it but still cant wait to get the b16 in and **** few more months
PINKS
Jan 29, 2006 05:10 PM
Markis.
Jan 3, 2006 05:50 AM
