spark plugs
what is the correct proceedure to remove the spark plugs on a 2007 civic Si .I'd like to anti-seize them so they will come out at 100k[or am i worrying about nothing?it might take me 12 years to get 100k
You have to remove the wipers and the plastic trim to get at the cowl panel just above the valve cover, remove the cowl panel then you can get at the plug cover, then remove the plug cavity cover and you can remove the plugs.
It is not as easy as you think it is, if you are going thru the trouble of removing all of that install new plugs in while you are there, never pull a spark plug on anything unless you intend to change them.
BoydCivic2005
Honda Civic (2001 - 2005)
Dec 17, 2013 08:50 AM
gbingham
Apr 10, 2007 06:10 AM
