h22a dyno #'s tuned by Dardantuning
Old Dec 30, 2011 | 01:13 AM
99V-unit's Avatar
Default h22a dyno #'s tuned by Dardantuning
h22a motor bone stock. Skunk 2 manifold, rmf header, stock throttle body, 440cc injectors 2.5inch intake tuned by me on s300. First h-series ive tuned.
Made 210whp and 162wtq all motor on 91 pump gas on the dynojet that we call the "dream killer"
Sprayed 55shot single fogger dry shot and put down 276whp and 258.9wtq on 91 pump. Both timing and a/fs were conservative (unknown bottle pressure)
Not bad for stock h22 huh? H2b kit, 74mm throttle body and cams and it should make around 235-250whp all motor and 300whp+ on the 55shot.
I'm located in San Diego if anyone needs a tune done right the first time and garunteed!
here is the vid. http://youtu.be/351w6baDPyw
Old Dec 30, 2011 | 03:01 PM
eg6-jarhead's Avatar
Default Re: h22a dyno #'s tuned by Dardantuning
good work
Old Dec 30, 2011 | 08:00 PM
99V-unit's Avatar
Originally Posted by eg6-jarhead
good work
Thank you. Upping the shot to 100 and some cams soon.
Old Dec 31, 2011 | 06:25 PM
303-rice-boy's Avatar
straight h22 is that correct?no h2b?
Old Dec 31, 2011 | 06:48 PM
99V-unit's Avatar
Yah straight h22a, we just got the h2b kit so gonna slap that one on. Motor has always smoked a bit so we might rering it as well.
Old Jan 1, 2012 | 10:08 AM
MONSTERek4's Avatar
h22 are very friendly to high numbers all they need is a skunk manifold and a good header and bam your in the 215. the funny thing is when u baseline a h22 100% stock they make 155 hahah then u add a big header and a skunk manifold and bam...
Old Jan 1, 2012 | 12:38 PM
99V-unit's Avatar
THere was a bit more power left in this motor, but wanted to keep it conservative since the owner drives it on the street and beats on it. Gonna try a 76mm throttle body and some cams and h2b on it. It shou
coomplife05
Aug 9, 2013 02:07 PM
jordan_rael_420
Sep 8, 2010 10:52 AM
scUba-stEve
Jan 6, 2006 09:23 AM
precord96
Oct 17, 2004 08:57 AM
Timmay
Aug 28, 2004 07:02 AM
