FS: DC Sports TSX Header
Acura TSX Ceramic Header from DC Sports
Makes about +9Hp and 16lbs of torque! Dyno proven!
DC Sports Sports 4 into 1 and 4-2-1 header systems are dyno tested to outperform all comparable header systems on the market. Extensive research and development goes into each system to ensure the best performance for your TSX.
DC Sports 4-2-1 TWO-piece header for the Acura TSX features:
-- Dyno-testing for maximum performance
-- CAD-rendered, two-piece 4-2-1 design eases installation
-- CNC-machined O-rings eliminate leaks
-- 100% mild steel with ceramic coating
-- CNC mandrel bends with robotically-welded fittings that deliver perfect fit
-- CNC-machined and threaded flanges eliminate leaks
-- Equal length primary piping ensures optimum tuning of systems for more power across rpm range
-- Comprehensive instructions and all necessary hardware
Retails for $550, selling for $280. Less than 1000 miles on the header.
Product fits: 2004 Acura TSX (CL9 Chassis)
That's true. I think they messed up on your purchase. K motors stock are flipped from b so that mean the headers should be shaped completely different. Or at the least the bottom piece should be shaped opposite
wushubrian
Dec 8, 2005 11:15 PM
